[Geoserver-users] WPS request builder subprocess xml
Dear all,
I am using GeoServer 2.5.2 and I've noticed a problem with the WPS request
builder.
When I try to chain together three processes, using the SUBPROCESS input
type, the xml autogenerated in the form is missing an input parameter; but I
can't edit it by hand.
Then if I run the chain of processes I get the error "Failed to retrieve
value for input".
Is there any solution to fix this?
Thanks for the help,
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-request-builder-subprocess-xml-tp5183396.html
On Fri, Jan 23, 2015 at 3:59 PM, matteo.eccher <matteo.eccher@anonymised.com>
wrote:
Dear all,
builder.
I
value for input".
Have the builder generate the XML and then send it "by hand"
using the "demo requests" panel instead.
If this is happening with a built-in process you might want to open a bug
report at http://jira.codehaus.org/browse/GEOS
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
