[Geoserver-users] write catalog.xml
hi everybody,
I am using geoserver1.7.3,I want to write some params to catalog.xml by geoserver api.
my code:
String datastoreId=“geo”;
Map<String, String> map=new HashMap<String, String>();
//map.put(“spatial index”, “true”);
map.put(“namespace”, “http://www.openplans.org/topp”);
//map.put(“memory mapped buffer”, “true”);
map.put(“url”, “file:data/g/geo.shp”);
map.put(“charset”, “ISO-8859-1”);
Map<String, Map> datastore=new HashMap<String, Map>();
datastore.put(datastoreId, map);
Map<String,String> namespace=new HashMap<String,String>();
namespace.put(datastoreId, “topp”);
CatalogWriter cw=new CatalogWriter();
cw.dataStores(datastore, namespace);
File catalog = new File(“C:\Program File\Apache Software Foundation\Tomcat 5.5\webapps \geoserver\data\catalog.xml”);
cw.write(catalog);
but after running,result is
java.io.IOException: Could not write catalog to C:\Program File\Apache Software Foundation\Tomcat 5.5\webapps\geoserver\data\catalog.xml
where is wrong? what should i do?
thank you
jack
网易邮箱,中国第一大电子邮件服务商
Hi Jack,
Have you considered using the REST api for this? It is the recommended way to programatically
add data, in this case upload and auto-configure a shapefile.
Here are some docs:
http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/
That said, could there be a permissions issue with that directory. Does the user running the program
have write access?
-Justin
liuyunhuali wrote:
hi everybody,
     my code:
               String datastoreId="geo";
                //map.put("spatial index", "true");
                map.put("namespace", "http://www.openplans.org/topp&quot;\);
                //map.put("memory mapped buffer", "true");
                map.put("url", "file:data/g/geo.shp");
                map.put("charset", "ISO-8859-1");
                namespace.put(datastoreId, "topp");
                File catalog = new File("C:\\Program File\\Apache Software Foundation\\Tomcat 5.5\\webapps \\geoserver\\data\\catalog.xml");
                cw.write(catalog);
thank you
jack
ÍøÒ×ÓÊÏ䣬ÖйúµÚÒ»´óµç×ÓÓʼþ·þÎñÉÌ <http://email.163.com>
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
