I am using Geoserver 1.7.0
I tried to add a FeatureType that is based an the "900913"-CRS.
Geoserver uses the following SRS for the "Google Projection":
PROJCS["WGS84 / Google Mercator",
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Longitude", EAST],
AXIS["Latitude", NORTH],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["semi_minor", 6378137.0],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0],
PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["x", EAST],
AXIS["y", NORTH],
AUTHORITY["EPSG","900913"]]
As far as I know is the datum of the "Google Projection" a sphere and not
the WGS84 ellipsoid.
http://spatialreference.org/ref/user/google-projection/
By the way, the EPSG published an update on their
http://www.epsg.org/Geodetic.html crs list including a new "web mapping
crs" (EPSG:3785):
PROJCS["Popular Visualisation CRS / Mercator",
GEOGCS["Popular Visualisation CRS",
DATUM["Popular Visualisation Datum",
SPHEROID["Popular Visualisation Sphere",6378137,0,
AUTHORITY["EPSG","7059"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6055"]],
PRIMEM["Greenwich",0,
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9102"]],
AXIS[E,EAST],
AXIS["N",NORTH],
AUTHORITY["EPSG","4055"]],
PARAMETER["False_Easting",0],
PARAMETER["False_Northing",0],
PARAMETER["Central_Meridian",0],
PARAMETER["Latitude_of_origin",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["East",EAST],
AXIS["North",NORTH],
AUTHORITY["EPSG","3785"]]
http://www.sharpgis.net/post/2008/05/SphericalWeb-Mercator-EPSG-code-3785.aspx
View this message in context: http://www.nabble.com/Wrong-Google-Projection-900913--tp20517742p20517742.html
