Hello list,
i am trying to run Geoserver 1.6.5 on a machine with Tomcat 5. The operating system ist Suse.
Geoserver correctly handels all XML-based requests like WFS-getFeature or getCapabilities. But when I start a getMap-Request, the Tomcat is shut down. These are the error messages:
X connection to localhost:15.0 broken (explicit kill or server shutdown).
X11 connection rejected because of wrong authentication.
Has anyone an idea how to solve this problem?
Matthias Drews ha scritto:
Hello list,
Shuts down? Which JDK are you using? GeoServer works fine with Sun
JDK, I'd advise against using OpenJDK for the time being.
A Sun JDK should complain that X cannot be reached, but definitely
should not shout down.
Besides that, you should start Tomcat adding the "-Djava.awt.headless=true" option so that it does not try to reach
for X (you can do so by adding the option among the java options
in tomcat/bin/catalina.sh).
Andrea Aime
OpenGeo - http://opengeo.org
Thank you!
Adding the headless-option solved the problem.
Matthias Drews
phone: +49 (89) 121528-0 mailto:matthias.drews@anonymised.com
fax: +49 (89) 121528-79 http://www.gaf.de
GAF AG Arnulfstr. 197 D-80634 Muenchen Germany
Vorstand: Dr. Peter Volk, Aufsichtsratsvorsitzender: Marcello Maranesi
Amtsgericht Muenchen HRB 140 509, Firmensitz: Muenchen
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet: Dienstag, 7. Oktober 2008 12:10
An: Matthias Drews
Betreff: Re: [Geoserver-users] X connection broken when requesting getMap
Hello list,
Shuts down? Which JDK are you using? GeoServer works fine with Sun JDK, I'd advise against using OpenJDK for the time being.
A Sun JDK should complain that X cannot be reached, but definitely should not shout down.
Besides that, you should start Tomcat adding the "-Djava.awt.headless=true" option so that it does not try to reach for X (you can do so by adding the option among the java options in tomcat/bin/catalina.sh).
Andrea Aime
