Geoserver WFS2.0 layer error publishing postgres float list type
  • GeoServer Version2.28.1 (and 2.26.2)
  • Git Revision80e103e11546c0cf79c52fb36c8c7cdb7bcd5828
  • Build Date24-Nov-2025 18:35
  • GeoTools Version34.1
Postgres table include a field with data type real (float list) generates error during parsing the list. The error is partially embedded in the wfs xml response - see depths field value below:
Partial response is:
wfs:member
<av_demo:LV_Cable_3D gml:id=“LV_Cable_3D.10”>
<av_demo:id>10</av_demo:id>
<av_demo:Diameter>100</av_demo:Diameter>
<av_demo:QL_code>B</av_demo:QL_code>
<av_demo:geom>
<gml:LineString srsName=“http://www.opengis.net/gml/srs/epsg.xml#2193” srsDimension=“3” gml:id=“LV_Cable_3D.10.geom”>
gml:posList1763451.40631793 5914950.70374772 33.4 1763449.47306134 5914951.07394579 33.4 1763450.99498674 5914962.17988794 33.2 1763450.00779189 5914963.53728087 33.2 1763452.02331472 5914979.04446676 33.25 1763455.745862 5915012.25946041 35.4 1763455.86926135 5915013.20552215 35.45 1763432.01205229 5915006.58308998 35.3</gml:posList>
</gml:LineString>
</av_demo:geom>
<av_demo:depths>[Ljava.lang.Float;@1689df0e</av_demo:depths>
</av_demo:LV_Cable_3D>
</wfs:member>
An example request is:
https://registration.augview.net/geoserver/av_demo/ows?service=WFS&version=2.0.0&request=GetFeature&srsname=EPSG:2193&bbox=1763445.9967241,5914969.0689081,1763453.20790121,5914976.2800852,EPSG:2193&typename=av_demo:LV_Cable_3D
Source data as reported by pg_admin is:
“id”,“Diameter”,“QL_code”,“depths”,“geom”
10,100,“B”,“{0.5,0.6,0.75,NULL,0.5,NULL,0.6,0.65}”,"SRID=2193;LINESTRING(1763451 ……
It appears that the list structure is not being correctly parsed.
The WFS2.0 documentation indicates that list types should be supported via nested xml structures.
There may be a Geoserver WFS setting that we have missed. We have not enabled the WFS configuration option labelled ‘Activate complex to simple features conversion’
Any assistance appreciated.
regards
Mike
For GeoJSON maybe, but for GML one needs to install and configure either the application schema or the feature templating plugin (for both it’s quite a bit of work, but features templating is a bit easier).
Can you point me to the documentation that states it’s supported out of the box?
Hi. thanks for your response
see section 10.3 or 11.2 of the WFS2.0 standard (Open Geospatial Consortium) for response semantics. I think it should be handled by either a tuple structure or a complex element structure.
I dont think it has anything to do with the spatial concepts of GML or GeoJSON as its just a regular attribute (non-spatial) so should be handled by the regular attribute parsing and xml structuring as defined by the attribute property response.
I will however take a look at feature templating plugin & application schema. Any suggestions for recommended reading please?
regards
Mike
