GeoTools / GeoServer PMC meeting - 2024-10-22
Attending- Torben Barsballe
  • Jukka Rahkonnen
  • Peter Smythe
  • Gabriel Roldan
  • Andrea Aime
  • Jody Garnett
Actions from prior meetings:- [DONE] Jody: Allow Discourse owners to view users
  • [DONE] Jody: Investigate automatic unpinning of topics
  • [DONE] Dave/Andrea: Try and fix some wicket tests
Agenda- GeoServer 2.25.4 release
  • Discourse
  • OSGeo Budget
  • CSP “proposal”
  • OAuth2 Rewrite
  • Wicket 9
  • PMD Update
  • GeoServer 3 Updates
  • Palantir
Actions- Jody: Send CSP proposal to vote when Steve has confirmed default functionality is “fine”, and regex is only required if user wants to allow something
Lack of release manager.
  • Jody has one quick fix to consider, and then is happy to volunteer … on Friday
Discourse- How is it going?
  • Easier to ask, but there is no incentive to stay and answer questions
  • Gameification? Yes same as stackoverflow if we want it
  • SAC changed mute settings a couple different ways to try and get "mailing list mode” to work (so you can see your replies)
  • Mailing list mode is available under Profile > Preferences > Email
  • To help test visit:
    https://discourse.osgeo.org/t/should-we-set-mute-categories-by-default/110412
OSGeo Budget and AGM Slides
Board meeting next week, and are starting to ask the projects for budget
  • Not sure if OSGeo has much money these days :slightly_smiling_face:
Also AGM slides:
  • request sent sent Simeone and Jody has “officers”
  • action: Jody to draft something and share for review
What do we want to say?
  • GeoServer Roadmap challenge, thanks those who responded, and GeoServer 3 as a response
  • We could talk about community challenges:
  • release candidates → nightly build due to lack of participation
  • negotiate with our user community a bit
  • 25k downloads per week
  • lol that is going to be Docker starting up :slight_smile:
    https://sourceforge.net/projects/geoserver/files/
  • Trying out the CRA policy, with a real “fire” … how to contact 10k instances?
  • AGM is interested in the team, most projects talk about features though
GeoTools:
  • Mostly the transition to ImageN etc…
CSP “proposal”
Jody turned it into a proposal for “discussion” (so we can figure out what it does):
Still a couple Regexes, but not as many as before:
Action:
  • Jody: Send proposal to vote when Steve has confirmed default functionality is “fine”, and regex is only required if user wants to allow something
OAuth2 Rewrite
https://github.com/geoserver/geoserver/pull/7968
Draft, work in progress, any feedback requested?
  • Andreas tried to reuse existing spring functionality and configure it to do what is needed
  • This is an entire rewrite, some level of code duplication to address before being ready for review
Open for initial feedback!
Wicket 9
Wicket 9 is merged, folks can now test nightly builds.
We do not have a driver of this activity, to listen to feedback and resolve problems, so “team effort” would be appreciated?
  • tile layer page preview not working, GEOS-11573
  • instance id not properly formatted any more
  • example the “style layer” page is not fully working
  • external graphic style is not displayed correctly
  • We are collecting feedback in google document for now: Wicket 9 Test Plan
  • Can we switch to Jira? Yes for the fixes
  • The document was more about the CSP warnings and fixing those ahead of Wicket 10
PMD 7 Update
https://github.com/geoserver/geoserver/pull/7577
Mostly done by Marc!
  • Andrea rescued from going stale
  • 700 files! Lots of small things
  • GWS and GS done
  • GT was too far behind, so not done …
GeoServer 3 Updates
The funding target is announced:
Request:
  • Please share, talk to your costumes, talk to your boss, etc…
Palantir
Sauron wants his ring back
Andrea was talking about this earlier, but was blocked until Wicket 9 :slight_smile:
https://github.com/geotools/geotools/pull/4944
  • POM change is really small https://github.com/geotools/geotools/pull/4944/commits/fc91f7657720214830217452a9302ceacf99531a
  • upgrade spotless, change formatter
  • resulting change touches most things
  • so we would need to do all active branches; and merge in all the live PRs first
  • How much?
  • GeoTools removes 70k lines
  • Helps a lot with wicket code due to use of inner classes
  • Q: Why spotless? Probably speed :slight_smile:
  • Original PR: https://github.com/geotools/geotools/pull/3761
  • And JIRA: GEOS-10382
  • From original discussions (Feb 2021 - Feb 2022):
  • Can run in parallel (unlike Eclipse formatter), supports XML formatting, can run alongside the Google Java Formatter
  • allows to freely choose the version of google-java-format to be used
  • Better supported than most other candidates
Proposal?
  • all automated …
  • but it is disruptive for the team (stale PRs etc…)
Feedback:
  • Gabe and Andrea really think this looks better
  • It is a good time in project release cycle
  • 2.27.x: main
  • 2.26.x: stable
  • 2.25.x: maintenance
  • older … as needed in case of emergency, apply formatter and then backport fix
  • How many PRs to fix:
  • GeoTools: 14 …
  • WCS: 5 …
  • GeoServer: 22 …
To help:
  • one commit for the pom.xml change, allow cherry-pick
  • one commit for the reformatting
Chitchat- OGCAPI Code Sprint First week of November!
  • SPDX-License-Identifier: MIT
2,664 files changed
+2678
-45336
lines changed
I am repling to this topic as a test of “mailing list mode” sending me my own replies.
Recently they muted categories so you can safely try “mailing list mode” and not be notified of everything happening everywhere all at once.
I received this message okay, I think mailing list mode works.
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
Just enabled… answering from forum, let’s see if I get the message by mail as well.
Yep, it took a few minutes but got into email. So yes, this works for basic message exchanges.
Anything that involves code examples, URLs and the like is probably still better edited from the forum directly though,
or it will be interpreted as markdown.
