GetFeatureInfo displaced result when using multiple CRSs in a single mosaic
Hi users.
I´m having trouble when i use GetFetureInfo against a image mosaic whose granules are in two different projections (EPSG:25830 and EPSG: 25828). If i click around the center of the pixel all woks fine, but if i click near the border, i obtain the value of the contiguous pixel.
When all granules of the mosaic are in the same projection (SRS) all works fine.
I´ve tested that cartografy is well georeferenced and the image that i obtain from WMS is ok, the displacement only occurs when requesting GetFeatureInfo
If i click at the center of the pixels, i obtain correct value:
When clicking near the border of the pixels, i obtain the value of the contiguous ones:
For example, if I click at the border of a red pixel (value=73.23) i obtain the value of the white one (value=-3.40) next to it:
In .properties i use:
Heterogeneous=true
HeterogeneousCRS=true
MosaicCRS=EPSG:25830
And at index file (SHAPEFILE) i have SRS field
Any ideas on how to correct this trouble?
Regards.
Hi Pedro,
by the looks of the image, I see you’re issuing a GetFeatureInfo with a 50
to 100 times oversampling factor
(1 pixel is represented as a 50x50 to 100x100 pixels), small numerical
issues are inflated significantly in that scenario.
I’m not aware of a magic “make it work” flag, code analysis and changes
seem the best way to approach this.
See this guide to get it done:
Andrea Aime
Visit GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail
On Thu, Sep 19, 2024 at 12:14 AM Pedro Briones via OSGeo Discourse <
noreply@discourse.osgeo.org> wrote:
pbg https://discourse.osgeo.org/u/pbg
September 18
Hi users.
fine.
GetFeatureInfo
contiguous ones:
[image: image]
https://discourse.osgeo.org/uploads/default/original/2X/9/92dd7f0173cccaa84554efd9282ca909fba07ccd.png
Heterogeneous=true
Regards.
Visit Topic
https://discourse.osgeo.org/t/getfeatureinfo-displaced-result-when-using-multiple-crss-in-a-single-mosaic/50935/1
or reply to this email to respond.
To unsubscribe from these emails, click here
https://discourse.osgeo.org/email/unsubscribe/0667b86781c56015ff73bab420030fc362f82c55a0e0a348069f90674345ea7c
Hi, Andrea. Thank you very much for your reply.
I think it is a problem related to defining an image mosaic with two different SRS granules: if the mosaic is made up of granules in a single SRS, GetFeatureInfo works fine, regardless of zoom level and the oversampling factor.
The same problem arises when I create a request and send it to the server without a graphic interface (from the browser URL bar), asking for a point near the border of the pixel, as in the following example (the value of X is30, meaning its 30 pixels away from the border):
http://<server_name>/geoserver/SIAR/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=SIAR:UsosSueloRegadio_Anual&tiled=true&STYLES=SIAR:UsosSuelo&LAYERS=SIAR:UsosSueloRegadio_Anual&exceptions=application/vnd.ogc.se_inimage&TIME=2023-01-01&INFO_FORMAT=application/json&X=30&Y=192&WIDTH=256&HEIGHT=256&SRS=EPSG:25830&BBOX=423970.0001295,4420970.0003883,423990.0001732,4420990.0004876
Regards
