Salve.
Qualcuno sa come si controlla se uno shp e' tridimensionale?
ogrinfo non mi pare dica nulla in proposito.
Grazie.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
2008/10/29 Paolo Cavallini <cavallini@faunalia.it>:
Salve.
Dovrebbe perĂ² (se i dati sono veramente 3D):
(per creare random3d_hull, vedi Example 2:
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.ogr.html )
GRASS 6.4.svn (latlong):~ > v.out.ogr random3d_hull \
dsn=/tmp/random3d_hull.shp type=face lco="SHPT=POLYGONZ"
WARNING: No attribute table found -> using only category numbers as
attributes
Exporting 64 faces (may take some time) ...
100%
2080 features written
ogrinfo -so /tmp/random3d_hull.shp
INFO: Open of `/tmp/random3d_hull.shp'
using driver `ESRI Shapefile' successful.
1: random3d_hull (3D Polygon) <<<<<<<<<-------- !
ogrinfo -so /tmp/random3d_hull.shp random3d_hull
Layer name: random3d_hull
Geometry: 3D Polygon <<<<<<<<<-------- !
Feature Count: 2080
Extent: (-78.682639, 35.732792) - (-78.674995, 35.739526)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]]
cat: Real (11.0)
ciao,
OK, ora e' chiaro:
Polygon = 2D Polygon
Grazie mille!
pc
