Allora, scusate il paciugo del work in progress.
Diciamo che nel mio mainapp faccio
from pyarchinit_print_utility import Print_utility
#collego la funzione al bottone
def on_pushButton_pdf_exp_pressed(self):
PU = Print_utility(self.iface, self.DATA_LIST)
PU.first_batch_try()
Poi ho il file incriminato:
testerDialog
A QGIS plugin
test print
begin : 2012-06-20
copyright : (C) 2012 by luca
email : pyarchinit@gmail.com
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation; either version 2 of the License, or *
* (at your option) any later version. *
import os
from PyQt4 import QtCore, QtGui
from PyQt4.QtCore import *
from PyQt4.QtGui import *
import PyQt4.QtGui
from qgis.core import *
from qgis.gui import *
#from ui_tester import Ui_tester
# create the dialog for zoom to point
class Print_utility:
if os.name == 'posix':
HOME = os.environ['HOME']
elif os.name == 'nt':
HOME = os.environ['HOMEPATH']
FILEPATH = os.path.dirname(__file__)
LAYER_STYLE_PATH = ('%s%s%s%s') % (FILEPATH, os.sep, 'styles', os.sep)
SRS = 3004
layerUS = ""
layerQuote = ""
mapHeight = ""
mapWidth = ""
USLayerId = ""
tav_num = ""
us = ""
uri = ""
def __init__(self, iface, data):
self.iface = iface
self.data = data
#self.area = area
#self.us = us
self.canvas = self.iface.mapCanvas()
# set host name, port, database name, username and password
def on_pushButton_runTest_pressed(self):
self.first_batch_try()
def first_batch_try(self):
#f = open("/test_print_2.txt", "w")
#f.write(str(self.sito))
#f.close()
for i in range(len(self.data)):
test = self.charge_layer_postgis(self.data[i].sito,
self.data[i].area, self.data[i].us)
self.us = self.data[i].us
if test != 0:
self.test_bbox()
tav_num= i+1
self.print_map(tav_num)
else:
pass
for i in self.data:
self.charge_layer_postgis(i.sito,i.area,i.us)
self.test_bbox()
self.print_map(i)
def converter_1_20(self, n):
n *= 100
res = n / 20
return res
def test_bbox(self):
self.layerUS.select( ) # recuperi tutte le geometrie senza attributi
featPoly = QgsFeature() # crei una feature vuota per il poligono
dizionario_id_contains = {}
lista_quote =
self.layerUS.nextFeature( featPoly ) # cicli sulle feature
recuperate, featPoly conterra la feature poligonale attuale
bbox = featPoly.geometry().boundingBox() # recupera i punti nel bbox
del poligono
self.height = self.converter_1_20(float(bbox.height())) * 0.5 #la
misura da cm e' portata in mm
self.width = self.converter_1_20(float(bbox.width())) * 0.5 #la
#f = open("/test_paper_size_5.txt", "w")
#f.write(str(self.width))
#f.close()
def getMapExtentFromMapCanvas(self, mapWidth, mapHeight, scale):
#code from easyPrint plugin
print "in methode: " + str(scale)
xmin = self.canvas.extent().xMinimum()
xmax = self.canvas.extent().xMaximum()
ymin = self.canvas.extent().yMinimum()
ymax = self.canvas.extent().yMaximum()
xcenter = xmin + (xmax - xmin) / 2
ycenter = ymin + (ymax - ymin) / 2
mapWidth = mapWidth * scale / 1000 #misura in punti
mapHeight = mapHeight * scale / 1000 #misura in punti
f = open("/test_paper_size_3.txt", "w")
f.write(str(mapWidth))
f.close()
minx = xcenter - mapWidth / 2
miny = ycenter - mapHeight / 2
maxx = xcenter + mapWidth / 2
maxy = ycenter + mapHeight / 2
return QgsRectangle(minx, miny, maxx, maxy)
def print_map(self, tav_num):
self.tav_num = tav_num
mapRenderer = self.iface.mapCanvas().mapRenderer()
c = QgsComposition(mapRenderer)
c.setPlotStyle(QgsComposition.Print)
#map - this item tells the libraries where to put the map itself.
Here we create a map and stretch it over the whole paper size:
x, y = 0, 0 #angolo 0, o in alto a sx
width, height = self.width*5, self.height*5 #da un valore alla
larghezza e altezza del foglio aumentato di 5 per dare un margine
dpi = 100 #viene settata la risoluzione di stampa
c.setPaperSize(width, height) #setta le dimensioni della pagina
f = open("/test_paper_size_1.txt", "w")
f.write(str(width))
f.close()
composerMap = QgsComposerMap(c, x, y, width, height) #crea un
mapComposer passandogli la classere Composition che a sua volta ha
incapsulato con la classe mapRenderer il canvas corrente
rect = self.getMapExtentFromMapCanvas(c.paperWidth(),
c.paperHeight(), 20.0) #ricava la mappa in scala da inserire nel
compositore passando le dimensioni di pagina in mm e ricavandoli in
punti
f = open("/test_paper_size_2.txt", "w")
f.write(str(c.paperWidth()))
f.close()
composerMap.setNewExtent(rect) #setta l'estensione della mappa
c.addItem(composerMap) #aggiunge la mappa alla composizione c
#aggiunge la scale bar
item = QgsComposerScaleBar(c)
item.setStyle('Numeric') # optionally modify the style
item.setComposerMap(composerMap)
item.applyDefaultSize()
c.addItem(item)
#width = 1189
#height = 841
#c.setPaperSize(width, height)
c.setPrintResolution(dpi) #setta la risoluzione di stampa
#Output to a raster image
#The following code fragment shows how to render a composition to a
raster image:
f = open("/test_paper_size_4.txt", "w")
f.write(str(dpi))
f.close()
dpmm = dpi / 25.4 #ricava il valore dei punti per mm
width_point = float(dpmm * c.paperWidth())
height_point = float(dpmm * c.paperHeight())
# create output image and initialize it
image = QImage(QSize(width_point, height_point), QImage.Format_ARGB32)
image.setDotsPerMeterX(dpmm * 1000)
image.setDotsPerMeterY(dpmm * 1000)
image.fill(0)
# render the composition
imagePainter = QPainter(image)
sourceArea = QRectF(0, 0, c.paperWidth(), c.paperHeight()) #viene
settata l'area sorgente con le misure in mm della carta
targetArea = QRectF(0, 0, width_point, height_point) #viene settata
l'area in cui inserire la mappa con le misure in punti per mm
c.render(imagePainter, targetArea, sourceArea)
imagePainter.end()
tav_name = ("/pyarchinit_print_tester_folder/Tavola_%d_us_%d.png") %
(self.tav_num+1, self.us)
image.save(str(tav_name), "png")
#QgsMapLayerRegistry.instance().removeMapLayer(layer_id)
#Output to PDF
#The following code fragment renders a composition to a PDF file:
printer = QPrinter()
printer.setOutputFormat(QPrinter.PdfFormat)
printer.setOutputFileName("/out.pdf")
printer.setPaperSize(QSizeF(self.mapWidth, self.mapHeight),
QPrinter.Millimeter)
printer.setFullPage(True)
printer.setColorMode(QPrinter.Color)
printer.setResolution(c.printResolution())
pdfPainter = QPainter(printer)
paperRectMM = printer.pageRect(QPrinter.Millimeter)
paperRectPixel = printer.pageRect(QPrinter.DevicePixel)
c.render(pdfPainter, paperRectPixel, paperRectMM)
pdfPainter.end()
QgsMapLayerRegistry.instance().removeMapLayer(self.USLayerId)
def open_connection(self):
self.uri = QgsDataSourceURI()
self.uri.setConnection('127.0.0.1','5432', 'mioDB', 'postgres', 'miapass')
def charge_layer_postgis(self, sito, area, us):
self.open_connection()
srs = QgsCoordinateReferenceSystem(3004,
QgsCoordinateReferenceSystem.PostgisCrsId)
gidstr = ("scavo_s = '%s' and area_s = '%s' and us_s = '%d'") %
(sito, area, us)
#f = open("/test_print.txt", "w")
#f.write(str(gidstr))
#f.close()
self.uri.setDataSource("public", "pyarchinit_us_view", "the_geom", gidstr)
self.layerUS = QgsVectorLayer(self.uri.uri(), "US", "postgres")
if self.layerUS.isValid() == True:
self.layerUS.setCrs(srs)
self.USLayerId = self.layerUS.getLayerID()
#self.mapLayerRegistry.append(USLayerId)
style_path = ('%s%s') % (self.LAYER_STYLE_PATH, 'us_caratterizzazioni.qml')
self.layerUS.loadNamedStyle(style_path)
self.iface.mapCanvas().setExtent(self.layerUS.extent())
QgsMapLayerRegistry.instance().addMapLayer( self.layerUS, True)
else:
return 0
#QMessageBox.warning(self, "Messaggio", "Geometria inesistente",
QMessageBox.Ok)
gidstr = "sito = 'test'"
uri.setDataSource("public", "pyarchinit_punti_rif", "the_geom", gidstr)
self.layerGriglia = QgsVectorLayer(uri.uri(), "Griglia a 50 cm", "postgres")
if self.layerGriglia.isValid() == True:
self.layerGriglia.setCrs(srs)
layerGrigliaId = self.layerGriglia.getLayerID()
#style_path = ('%s%s') % (self.LAYER_STYLE_PATH, 'stile_griglia.qml')
#self.layerGriglia.loadNamedStyle(style_path)
#self.iface.mapCanvas().setExtent(self.layerUS.extent())
QgsMapLayerRegistry.instance().addMapLayer( self.layerGriglia, True)
else:
print "layerGriglia US is not valid!!!"
uri.setDataSource("public", "pyarchinit_uscaratterizzazioni_view",
"the_geom", gidstr)
layerCar = QgsVectorLayer(uri.uri(), "Unita' Stratigrafiche", "postgres")
if layerCar.isValid() == True:
layerCar.setCrs(srs)
CARLayerId = layerCar.getLayerID()
self.mapLayerRegistry.append(CARLayerId)
#style_path = ('%s%s') % (self.LAYER_STYLE_PATH, 'us_caratterizzazioni.qml')
# self.layerUS.loadNamedStyle(style_path)
QgsMapLayerRegistry.instance().addMapLayer(layerCar, True)
else:
print "Layer Caratterizzazioni is not valid!!!"
gidstr = "gid = 2257 or gid = 2849 or gid = 2443 or gid = 2370 or
gid = 2297 or gid = 2852 or gid = 2299 or gid = 2225 or gid =
2226 or gid = 2448 or gid = 2862 or gid = 2863 or gid = 2717 or gid =
2718 or gid = 2427 or gid = 2429 or gid = 2245 or gid = 2652 or
gid = 2285 or gid = 2287 or gid = 2288 or gid = 2289 or gid = 2844 or
gid = 2290 or gid = 2475 or gid = 2845 or gid = 2328"
uri.setDataSource("public", "pyarchinit_quote", "the_geom", gidstr)
self.layerQuote = QgsVectorLayer(uri.uri(), "Quote", "postgres")
if self.layerQuote.isValid() == True:
self.layerQuote.setCrs(srs)
QuoteLayerId = self.layerQuote.getLayerID()
#self.mapLayerRegistry.append(QuoteLayerId)
QgsMapLayerRegistry.instance().addMapLayer(self.layerQuote, True)
else:
print "Layer Quote is not valid!!!"
#Print section
# create image
