Ciao,
mi sono appena scaricato i sorgenti di spatialite_gui-1.5.0-beta1a ma ho
alcuni problemi di installazione. Lavoro su ubuntu 10.04 con architettura AMD
64bit.
Il .configure va liscio come l'olio ma il "sudo make && make install" mi si
inchioda dopo un buon inizio con questo messaggio finale:
"/usr/include/spatialite.h: In member function ‘void MyFrame::OnSqlScript
(wxCommandEvent&)’:
/usr/include/spatialite.h:65: error: too many arguments to function ‘int
load_shapefile(sqlite3*, char*, char*, char*, int, char*, int, int, int, int*)’
Main.cpp:1983: error: at this point in file
/usr/include/spatialite.h:70: error: too many arguments to function ‘int
load_dbf(sqlite3*, char*, char*, char*, int, int*)’
Main.cpp:1997: error: at this point in file
Main.cpp:2013: error: ‘load_XL’ was not declared in this scope
/usr/include/spatialite.h:61: error: too many arguments to function ‘int
dump_shapefile(sqlite3*, char*, char*, char*, char*, char*, int, int*)’
Main.cpp:2029: error: at this point in file
Main.cpp: In member function ‘void MyFrame::OnLoadShp(wxCommandEvent&)’:
Main.cpp:2173: error: invalid conversion from ‘int’ to ‘int*’
Main.cpp:2173: error: at this point in file
/usr/include/spatialite.h: In member function ‘void MyFrame::OnLoadDbf
(wxCommandEvent&)’:
Main.cpp:2510: error: at this point in file
Main.cpp: In member function ‘void MyFrame::OnLoadXL(wxCommandEvent&)’:
Main.cpp:2635: error: ‘load_XL’ was not declared in this scope
make[1]: *** [Main.o] Errore 1
make[1]: uscita dalla directory "/home/gianluca/Scaricati/spatialite_gui-1.5.0-
beta1a"
make: *** [all-recursive] Errore 1
Qualcuno può aiutarmi?
Gianluca
