ciao,
sto cercando di compilare le GDAL 1.9 da sorgente (su debian
unstable) ma ottengo degli errori.
Ecco il configure:
$ ./configure --with-spatialite=/usr/local
che restituisce:
GDAL is now configured for i686-pc-linux-gnu
Installation directory: /usr/local
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
LIBTOOL support: yes
LIBZ support: external
LIBLZMA support: no
GRASS support: no
CFITSIO support: no
PCRaster support: internal
LIBPNG support: external
GTA support: no
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: external
8/12 bit JPEG TIFF: no
LIBGIF support: external
OGDI support: no
HDF4 support: yes
HDF5 support: yes
NetCDF support: yes
Kakadu support: no
JasPer support: yes (GeoJP2=yes)
OpenJPEG support: no
ECW support: no
MrSID support: no
MrSID/MG4 Lidar support: no
MSG support: no
GRIB support: yes
EPSILON support: no
WebP support: no
cURL support (wms/wcs/...):yes
PostgreSQL support: yes
MySQL support: no
Ingres support: no
Xerces-C support: yes
NAS support: yes
Expat support: yes
Google libkml support: no
ODBC support: yes
PGeo support: yes
FGDB support: no
MDB support: no
PCIDSK support: internal
OCI support: no
GEORASTER support: no
SDE support: no
Rasdaman support: no
DODS support: no
SQLite support: yes
SpatiaLite support: yes
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: yes
VFK support: yes
Poppler support: no
Podofo support: no
OpenCL support: no
Armadillo support: no
FreeXL support: yes
SWIG Bindings: no
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: yes
enable POSIX iconv support:yes
hide internal symbols: no
mentre il make si interrompe con questo messaggio:
libtool: compile: g++ -g -O2 -Wall -I/home/sit/src/gdal/port
-I/home/sit/src/gdal/gcore -I/home/sit/src/gdal/alg
-I/home/sit/src/gdal/ogr -I/home/sit/src/gdal/ogr/ogrsf_frmts
-I/home/sit/src/gdal/frmts -DOGR_ENABLED -I/home/sit/src/gdal/port -c
ogr2ogr.cpp -o ogr2ogr.o >/dev/null 2>&1
gdalbuildvrt.cpp -o gdalbuildvrt.o >/dev/null 2>&1
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_open_v2'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_bind_blob'
`SPLite3_column_blob'
`SPLite3_column_type'
`SPLite3_column_name'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_bind_text'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_exec'
`SPLite3_column_double'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_reset'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_get_table'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_vfs_find'
`SPLite3_column_count'
`SPLite3_last_insert_rowid'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_errmsg'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_column_int'
`SPLite3_bind_double'
`SPLite3_column_decltype'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_prepare_v2'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_finalize'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_free_table'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_free'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_bind_int'
`SPLite3_vfs_register'
`SPLite3_vfs_unregister'
`SPLite3_libversion_number'
`SPLite3_column_text'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_close'
`SPLite3_column_bytes'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_step'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_bind_null'
/home/sit/src/gdal/.libs/libgdal.so: undefined reference to `SPLite3_prepare'
collect2: ld returned 1 exit status
make[1]: *** [gdaladdo] Error 1
make[1]: Leaving directory `/home/sit/src/gdal/apps'
make: *** [apps-target] Error 2
Qualcuno ha qualche idea in merito?
ciao e grazie per qualsiasi aiuto
flavio
