Ho dato un occchiata un po’ più approfondita ai dati.
con gdalinfo ho ottenuto per l’immagine originale questi dati:
gdalinfo DTEEC_009650_1755_009716_1755_U01.IMG
Driver: PDS/NASA Planetary Data System
Files: DTEEC_009650_1755_009716_1755_U01.IMG
Size is 8397, 24790
Coordinate System is:
PROJCS[“EQUIRECTANGULAR MARS”,
GEOGCS[“GCS_MARS”,
DATUM[“D_MARS”,
SPHEROID[“MARS_localRadius”,3396190,0]],
PRIMEM[“Reference_Meridian”,0],
UNIT[“degree”,0.0174532925199433]],
PROJECTION[“Equirectangular”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,137.3099975585938],
PARAMETER[“standard_parallel_1”,0],
PARAMETER[“false_easting”,0],
PARAMETER[“false_northing”,0]]
Origin = (-4448.740154027938843,-260917.547678232192993)
Pixel Size = (1.011767148971558,-1.011767148971558)
Metadata:
FILTER_NAME=
DATA_SET_ID=“MRO-M-HIRISE-5-DTM-V1.0”
PRODUCT_ID=“DTEEC_009650_1755_009716_1755_U01”
PRODUCER_INSTITUTION_NAME=“UNIVERSITY OF ARIZONA”
PRODUCT_TYPE=
MISSION_NAME=
SPACECRAFT_NAME=
INSTRUMENT_NAME=“HIGH RESOLUTION IMAGING SCIENCE EXPERIMENT”
INSTRUMENT_ID=“HIRISE”
TARGET_NAME=“MARS”
CENTER_FILTER_WAVELENGTH=
BANDWIDTH=
PRODUCT_CREATION_TIME=
NOTE=
Corner Coordinates:
Upper Left ( -4448.740, -260917.548) (137d14’5.80"E, 4d24’6.61"S)
Lower Left ( -4448.740, -285999.255) (137d14’5.80"E, 4d49’29.93"S)
Upper Right ( 4047.069, -260917.548) (137d22’41.79"E, 4d24’6.61"S)
Lower Right ( 4047.069, -285999.255) (137d22’41.79"E, 4d49’29.93"S)
Center ( -200.836, -273458.401) (137d18’23.79"E, 4d36’48.27"S)
Band 1 Block=8397x1 Type=Float32, ColorInterp=Undefined
NoData Value=-3.40282265508890445e+38
e per quella modificata questi:
gdalinfo DTEEC_009650_1755_009716_1755_U01_modificato.tif
Driver: GTiff/GeoTIFF
Files: DTEEC_009650_1755_009716_1755_U01_modificato.tif
Size is 8332, 24812
PROJCS[“unnamed”,
GEOGCS[“unnamed ellipse”,
DATUM[“unknown”,
SPHEROID[“unnamed”,3396190,0]],
PRIMEM[“Greenwich”,0],
PARAMETER[“central_meridian”,137.3],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]]]
Origin = (588.800866968106448,2079.030352636491443)
Pixel Size = (1.006502648693668,-1.006502648693668)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 588.801, 2079.030) (137d18’35.76"E, 0d 2’6.27"N)
Lower Left ( 588.801, -22894.313) (137d18’35.76"E, 0d23’10.47"S)
Upper Right ( 8974.981, 2079.030) (137d27’5.09"E, 0d 2’6.27"N)
Lower Right ( 8974.981, -22894.313) (137d27’5.09"E, 0d23’10.47"S)
Center ( 4781.891, -10407.642) (137d22’50.42"E, 0d10’32.10"S)
Band 1 Block=8332x1 Type=Float32, ColorInterp=Gray
Come si può vedere dal parametro SPHEROID non stò lavorando con immagini terrestri ma con immagini di marte, avendo marte appunto un raggio pari a circa la metà di quello terrestre.
Tutti i dati dell’immagine modificata sono giusti tranne “Origin”, infatti i valori dell’Upper Left sono completamente sballati. La Longitudine è giusta ma la latitudine dovrebbe essere intorno ai 4° invece che 0°
Sono sicuro che non è un’errore mio nel posizionamento dei GCPs.
Suggerimenti o idee?
Grazie
Il giorno 19 agosto 2010 09:55, andrea pacifici <pacifici@gmail.com> ha scritto:
Ciao Paolo,
nessun messaggio. l’immagine georeferenziata viene posizionata alla giusta longitudine ma completamente sballata in latitudine.
suggerimenti?
andrea
Il giorno 19 agosto 2010 09:16, Paolo Cavallini <cavallini@faunalia.it> ha scritto:
Il 19/08/2010 09:11, andrea pacifici ha scritto:
il georeferenziatore di qgis 1.5 su ubuntu 9.10 mi da sempre lo stesso
errore, sbagliando completamente la latitudine dell’immagine
georeferenziata.
Hai un messaggio di errore? Puoi descrivere meglio cosa succede?
Saluti.
Iscriviti all’associazione GFOSS.it: http://www.gfoss.it/drupal/iscrizione
Gfoss@faunalia.it
http://lists.faunalia.it/cgi-bin/mailman/listinfo/gfoss
le posizioni dell’Associazione GFOSS.it.
460 iscritti al 15.7.2010
Dott. Geol. Andrea Pacifici, Ph.D.
Via San Paolino n° 21,
55100 Lucca (Lu)
Tel. e Fax. 0583-080365
Cell. 328-0991808
web: www.geoitt.it
e-mail: pacifici@gmail.com
55100 Lucca (Lu)
Cell. 328-0991808
web: www.geoitt.it
