Interessante. Ma esiste qualcuno in Italia che lo usa?
Saluti.
pc
-------- Messaggio Originale --------
Dear freegis list,
The 52°North Geoprocessing Community is proud to announce the release of
the Web Processing Service Version 2.0! This new release contains the
following changes and extensions:
* *Sextante (http://www.sextantegis.com/en/index.htm) processes
integration*: the current 52N WPS now provides more than 220
Sextante geoalgorithms
(http://forge.osor.eu/plugins/wiki/index.php?id=13&type=g
<http://forge.osor.eu/plugins/wiki/index.php?id=13&type=g>\) as
real WPS processes. Sextante support can easily be
enabled/disabled and does not hinder custom developments of
individual processes.
* *GRID support*: any existing process or algorithm can be reused
and distributed in the grid for parallel execution. This release
enables the user to easily outsource geoprocessing tasks to an
external data processing center. It fully supports the widely
adopted UNICORE 6 grid middleware. In addition, it is possible to
support other grid middlewares (e.g. Globus Tookit 4). No
administrative access to the grid infrastrucutre is necessary,
only a valid certificate for accessing the target system is required.
* i*nternal architecture redesign* with new flexible bindings of
different internal datastructures (e.g. Geotools Datamodel)
* *support for (very large) rasters*
* *new Geotiff parser and generator*
* i*mproved asychronous datahandling + download of stored files*
* *several bugfixes*
* *extended Tutorial*: it guides the user through the process of
setting up the 52N WPS, creating a new process, as well as
executing and exporting the process. * *
The 52N Web Processing Service enables the deployment of geo-processes
on the web. It features a pluggable architecture for processes and data
encodings. The implementation is based on the current OpenGIS
specification: 05-007r7.
download tutorial here:
http://52north.org/twiki/bin/viewfile/Processing/52nWebProcessingService?rev=1;filename=WPS_Tutorial.pdf
download binary distribution here:
http://52north.org/index.php?option=com_jdownloads&Itemid=73&task=viewcategory&catid=22
<http://52north.org/index.php?option=com_jdownloads&Itemid=73&task=viewcategory&catid=22>
browse the sources in our svn repository here:
http://52north.org/svn/geoprocessing/main/WPS/trunk/WPS/
test instances can be invoked here:
http://52north.org:8080/wps/WebProcessingService
http://geoserver.itc.nl:8080/wps/WebProcessingService
more information can be found here:
http://52north.org/maven/project-sites/wps/52n-wps-webapp/
best regards,
Ann Hitchcock
Dipl.-Geogr. Ann Hitchcock
52°North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster
Germany
Geschäftsführer: Dr. Albert Remke, Dr. Andreas Wytzisk
Amtsgericht Münster HRB 10849
Tel.: +49 (0)251 74 74- 520
Fax: +49 (0)251 74 74- 530
hitchcock@52north.org
www.52north.org
Paolo Cavallini, see: * http://www.faunalia.it/pc *
