Inizio messaggio inoltrato:
Da: Frank Warmerdam <warmerdam@pobox.com>
Data: 09 maggio 2010 23.42.45 GMT+02.00
A: GeoTIFF <geotiff@lists.maptools.org>
Oggetto: [Geotiff] Libgeotiff 1.3.0 Released
Folks,
A couple months ago I prepared a libgeotiff 1.3.0RC2 and indicated if there
were no issues, I’d promote it to 1.3.0 final. I neglected to follow up on
that, but have finally done so. So the new release is at:http://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.3.0.tar.gz
http://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.3.0.zipThe ChangeLog entries are below, but the essential items are:
- Updated to EPSG 7.1 database.
- Upgrade to use full automake/libtool/autoconf suite of tools.
ChangeLog:
2010-01-12 Frank Warmerdam <warmerdam@pobox.com>
Preparing 1.3.0 release.
csv/*.c, cpl_csv_incode.c, geo_incode_defs.h, Makefile.am: rename
defs.h to geo_incode_defs.h and include it in distribution so incode
table support will work out of the box.2010-01-07 Frank Warmerdam <warmerdam@pobox.com>
geo_names.c: ensure that VerticalUnitsGeoKey works properly.
geo_write.c: switch SortKeys() to a simple bubble sort so we don’t
end up crashing when rewriting screwn geotiff tag sets with
duplicate geokeys (like some LAS files with multiple zero dummy tags)geo_new.c: resize short and double arrays bigger when reading
from an existing file to ensure we can update and add keys later.2010-01-03 Frank Warmerdam <warmerdam@pobox.com>
- Makefile.am: set versioninfo to 2:0:0 as required by the change for
1.3.0 in the ABI due to change of size of GTIFDefn structure.
(#19, GDAL #3309)2009-12-30 Frank Warmerdam <warmerdam@pobox.com>
- geo_new.c: fix computation of ascii key length introduced in past
fix a few months ago that was breaking the GTIFImport() logic. (#14)2009-11-11 Frank Warmerdam <warmerdam@pobox.com>
- geo_normalize.c: Recognise 9841 and 1024 projection methods as
CT_Mercator: http://trac.osgeo.org/gdal/ticket/32172009-10-19 Frank Warmerdam <warmerdam@pobox.com>
- csv/{gcs,pcs}.override.csv: Add comments on where the master lives
and incorporate COORD_SYS_CODE and Pulkovo 1942 GCS.2009-09-24 Frank Warmerdam <warmerdam@pobox.com>
geotiff_proj4.c: fix parameter mapping to proj4. for equirectangular
per http://trac.osgeo.org/gdal/ticket/2706autogen.sh: adjust to avoid version conflicts (#10).
geo_normalize.c/h, geotiff_proj4.c: Added DefnSet to GTIFDefn so
it can be properly established if a definition was set or if there
were no geokeys (#12). Corrects serious interim bug in geotiff_proj4.cgeo_new.c: avoid buffer overrun on corrupt input file (#14).
geo_print.c: Improve the precision when formatting values (#13).
2009-06-05 Paul Ramsey
- csv: Update the EPSG csv files to the 7.1 release of the database.
2009-06-03 Frank Warmerdam <warmerdam@pobox.com>
- geo_normalize.c: add support for LAEA, as contributed by EvenR.
http://trac.osgeo.org/gdal/ticket/30162009-05-20 Frank Warmerdam warmerdam@pobox.com
- csv/add_esri_column.py, csv/esri_datum_override.csv: Added a bunch
of manual ESRI datum name overrides - related to GDAL r17058.2009-05-18 Frank Warmerdam warmerdam@pobox.com
- COPYING: remove inadvertent GPL license, refer to LICENSE file.
2009-05-03 Frank Warmerdam warmerdam@pobox.com
- geo_print.c: Use %s format string in fprintf for arbitrary messages.
http://trac.osgeo.org/gdal/ticket/29762009-04-22 Frank Warmerdam warmerdam@pobox.com
geo_normalizec: Do not call CSVDeaccess() by default in getdefn -
leave it to the application.Remove all the $Log logs.
2009-04-03 Frank Warmerdam warmerdam@pobox.com
- geotiff_proj4.c: fix case for setting LCC 2SP GeoTIFF from proj.4.
2009-02-23 Frank Warmerdam warmerdam@pobox.com
*.c, *.h: Include appropriate copyright messages where missing (#8).
geotiff_proj4.c: Fix some buffer overflow holes (#9).
2009-02-18 Frank Warmerdam warmerdam@pobox.com
- geo_simpletags.c: compute “count” for ascii tag values.
2008-12-29 Frank Warmerdam warmerdam@pobox.com
geo_normalize.c: Optimizations to avoid opening CSV files for
“well known” definitions. (#4).geotiff_proj4.c: Reduce change of szUnits overflow (#3).
2008-11-27 Frank Warmerdam warmerdam@pobox.com
- geo_normalize.c: Introduce support for StdParallel1 in
Equirectangular (http://trac.osgeo.org/gdal/ticket/2706)2008-11-12 Frank Warmerdam warmerdam@pobox.com
- bin/applygeo.c: New utility for applying georeferencing to an
existing file (written by jeskynar@hotmail.com and myself).2008-10-24 Frank Warmerdam warmerdam@pobox.com
- bin/listgeo.c: Improve tfw error reporting and user hints (#2)
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
Geotiff mailing list
Geotiff@lists.maptools.org
http://lists.maptools.org/mailman/listinfo/geotiff
