We are pleased to announce the release of a new stable version of GRASS GIS. This release fixes bugs discovered in version 6.4.1 of the program and adds a number of new features. This release includes over 760 updates to the source code since 6.4.1. As a stable release series, the 6.4 line will enjoy long-term support and incremental enhancements while preserving backwards-compatibility with the entire GRASS 6 line.
The new wxPython graphical user interface (wxGUI) has been updated with many new features and tools. Python is now a fully supported scripting language, including an updated Python toolkit to simplify the authoring of personal scripts, support for NumPy based array calculations, and a Python application interface for the GRASS C libraries. Additionally, MS-Windows support continues to mature. GRASS 6.4.2 debuts ten new modules, a new GUI cartographic composer tool, a new GUI object-oriented modeling environment, and improved infrastructure for installing community supplied add-on modules.
The Geographic Resources Analysis Support System, commonly referred to as GRASS, is an Open Source Geographic Information System (GIS) and geospatial analysis toolkit. For nearly three decades, GRASS has provided powerful raster, vector, and geospatial processing engines in a single integrated software suite. GRASS includes tools for spatial modeling of raster and vector data, visualization, the management and analysis of geospatial information, and the processing of satellite and aerial imagery. It also provides the capability to produce sophisticated presentation graphics and publication-quality hardcopy maps. GRASS has now been translated into twenty languages and supports an extensive array of data formats. It is distributed under the terms of the GNU General Public License (GPL).
GRASS differs from many other GIS software packages used in the academic and professional worlds in that it is developed and distributed by users for users, mostly on a volunteer basis. Its code and spatial processing algorithms are open and transparent, and the software is distributed free of charge. The source code is also freely available, allowing for immediate customization, examination of the underlying algorithms, the addition of new features, and faster identification and patching of bugs.
On Mon, 20 Feb 2012 23:17:30 +0100, Markus Neteler wrote
GRASS GIS 6.4.2 released
Markus,
complimenti a te personalmente ed a tutto il team di sviluppo
di GRASS; avete fatto un ottimo lavoro che sicuramente rende
ben felici moltissimi affezionati utenti.
GRASS si conferma puntualmente come uno dei pilastri portanti
del variopinto ecosistema del sw geografico libero ed open
source. Sicuramente il progetto di piu' lunga durata (30 anni
di storia alle spalle non sono uno scherzo), ed ancor oggi
continua ad attrarre una community vivace ed attiva.
Ottimo lavoro, e tanti auguri di continuare cosi' per
molti, molti lunghi anni a venire
Grazie mille per la nuova versione! L’ho scaricata e installata ieri sera tramite osgeo4w, ma GRASS non funziona più, né indipendentemente, né integrato in QGIS (il plugin è smarrito). Provando a utilizzare solamente GRASS, il messaggio di errore è: “This application has failed to start because libintl3.dll was not found”.
Ho reinstallato GRASS ma il problema non è risolta. Credo che GRASS funzioni con la vecchia versione (che posso sostituire), ma vorrei provare questa nuova… Sono su Windows Vista.
I files dll sono di sistema e GRASS non puo pacchettizzarli perche violerebbe la licenza. Puoi risolvere il problema molto semplicemente scaricando il file dll mancante [1] e reinstallando GRASS.
Grazie mille per la nuova versione! L'ho scaricata e installata ieri sera
GRASS, il messaggio di errore è: "This application has failed to start
because libintl3.dll was not found".
I files dll sono di sistema e GRASS non puo` pacchettizzarli perche`
I files dll sono di sistema e GRASS non puo pacchettizzarli perche violerebbe la licenza. Puoi risolvere il problema molto semplicemente scaricando il file dll > mancante [1] e reinstallando GRASS.
Utilizzo QGIS e GRASS dal 2007 su Windows ed è per la prima volta che capita questa cosa. Mi chiedo perché finora GRASS funzionava sempre bene e non aveva dei “conflitti” con i file .dll.
Ringrazio tanto Mandi e Markus per l’aiuto. Non sono riuscita a risolvere il problema, ma proverò di nuovo domani sera. Forse aiuterà anche quel ticket aperto.
Dopo lo scarico dil file .dll in quale cartella devo metterlo? Non l’ho scaricato ancora perché non si connette al server di download (il problema della connessione per l’Internet, credo).
Scusa, ma in buona fede e cercando di rendermi utile, mi e scappata una boiata. Quel file che ti manca ha licenza libera. Comunque non avevo visto che e stato aperto il ticket sull’argomento, quindi ti consiglio di seguire quello che ti ha detto Markus. Scusa ancora per la confusione.
ciao,
madi
questa cosa.
Spero anche l'ultima ...
aveva dei "conflitti" con i file .dll.
Non è un conflitto ma semplicemente l'assenza. Credo che sia un
problema di packaging di winGRASS che è stato modificato
fortemente di recente per semplificare alcune cose. Sembra che
sia scappato questo file dalla lista da mettere dentro.
Penso basta nella cartella delle DLL di GRASS.
Se aiuta possiamo rifare il pacchetto di winGRASS.
Non l'ho
della connessione per l'Internet, credo).
scusate, non so se questo sia il posto giusto per segnalarlo, ma dopo aver
aggiornato, via osgeo, qgis sia all'ultima versione stabile (1.7.4-1) sia
all'ultima versione di sviluppo (1.9.90-70) e grass alla versione 6.4.2-2
con plugin grass per qis in versione 1.7.4-1, è scomparso il plugin grass
dalla lista dei plugin disponibili.
ho disinstallato tutto sempre via osgeo e re-installato tutto ma il plugin
grass è disponibile solo nella versione 1.7.4. mentre grass stand alone si
avvia senza problemi (s.o. win7).
pensate che possa essere correlato ai problemi di cui sopra?
Ho messo il file “libintl3.dll” nella cartella “bin” di GRASS e poi il programma mi a richiesto il file “libiconv2.dll”. L’ho copiato da un’altro portatile che aveva le precedenti versioni di GRASS e QGIS e l’ho incollato nella stessa cartella. Adesso GRASS si apre, ma non funziona bene, purtroppo. Per esempio non può leggere nessun file (“g.mlist.exe” non funziona). Persiste ancora il problema del plugin QGIS-GRASS, smarrito (sia nella versione 1.7.4 sia 1.9; c’è nella versione 1.7.3. installata dal file setup.exe).
Ho provato a reinstallare le vecchie versioni di GRASS e del plugin QGIS-GRASS, ma non ho risolto il problema. Penso di disinstallare tutto, ma ricordo che tramite osgeo4w questa cosa è difficile (mentre si sceglie di disinstallare un pacchetto si attivano altri e così via e non conosco un metodo per disinstallare tutti i pachetti e i programmi).
questa cosa.
Spero anche l’ultima …
Non è un conflitto ma semplicemente l’assenza. Credo che sia un
Non l’ho
Probabilmente c'è un mix di versioni sulla macchina?
L'unica soluzione che vedo è di pulire bene tutto...
Probabilmente c’è un mix di versioni sulla macchina?
L’unica soluzione che vedo è di pulire bene tutto…
Sì, ho la versione stabile e quella di sviluppo di QGIS installate tramite osgeo4w (e aggiornate molto spesso) e da qualche mese anche la versione installata dal file setup.exe che utilizzo per aprire i file .ecw. Ho già disinstallato quest’ultimo programma e mi faccio coraggio per disinstallare tutto il resto tramite osgeo4w. Dico “coraggio” pensando alle difficoltà affrontate un’altra volta, due anni fa, quando ho voluto pulire bene tutto (non sono riuscita a selezionare tutti i pacchetti installati ed ho perso molto tempo per disinstallare tutto).
Sa qualcuno qual è la modalità corretta e rapida per disinstallare QGIS + GRASS installati tramite osgeo4w?
aggiornato, via osgeo, qgis sia all’ultima versione stabile (1.7.4-1) sia
all’ultima versione di sviluppo (1.9.90-70) e grass alla versione 6.4.2-2
Ciao!
Ho risolto il problema del non funzionamento di GRASS come indicato da Markus (grazie!) e seguendo anche le indicazioni del ticket aperto: ho incolato nella cartella msys/bin i seguenti file: “libintl3.dll”, “libiconv2.dll”, “regex2.dll”. Adesso GRASS funziona bene, ma il plugin QGIS-GRASS è scomparso, dunque in QGIS non posso utilizzare GRASS. Non funziona nemmeno con la precedente versione del plugin.
Oggi ho aggiornato GIS (1.7.4. e 1.9) su un altro portatile (con XP), senza l’aggiornameno di GRASS (che mi ha fatto dei problemi) e, di nuovo, il plugin QGIS-GRASS è scomparso. Reinstallando 1.7.3. funziona…
QGIS 1.7.4 installato dal file setup.exe funziona perfetto (l’ho installato dopo, per provare il suo corretto funzionamento).
Ciao!
Allora, la soluzione coretta è la reinstallation del "Msys package".
ma il plugin
Magari aiuta l'installazione del "Msys package" e del plugin?
l'aggiornameno di GRASS (che mi ha fatto dei problemi) e, di nuovo, il
plugin QGIS-GRASS è scomparso. Reinstallando 1.7.3. funziona...
Come detto, bisogna partire con un PC "pulito".
QGIS 1.7.4 installato dal file setup.exe funziona perfetto (l'ho installato
Sarà simile per il standalone winGRASS...
Ciao
PS: Trovo sempre curioso che per un utente di Windows funziona
ma per un'altro no...
confermo che su tre diversi pc con s.o. win7 e xp l'aggiornamento di grass ha
portato alla scomparsa del plugin in qgis sia 1.7.4 sia trunk.
invece la versione stand alone di grass funziona senza problemi.
Bene!
Bene una sega (cit.).
Scherzi a parte, non e' bene che le cose si rompano. Nello specifico, e' stato aggiornato GRASS in osgeo4w senza ricompilare QGIS (o chiedere di farlo). Chiedo agli sviluppatori di GRASS, ed in particolare qui a Markus, di coordinarsi con il team di QGIS, in modo che quando qualcosa cambia in GRASS si possa prontamente adeguarsi in QGIS. Credo sia nell'interesse degli utenti tutti. Grazie mille.
Saluti.
grass ha
Bene!
farlo).
Sei sicuro di questo?
Mi rifiuto.
Faccio già abbastanza.
Oppure vice versa. Propongo di prima analizzare il problema.
