Interessante, no?
Io non sono ancora riuscito a vedere un punto, ma sono fiducioso ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
-------- Messaggio originale --------
Oggetto: [OSGeo-Discuss] GRASS GIS Web UI
Data: Fri, 5 Aug 2011 21:46:30 +0530
Mittente: Mohammed Rashad <mohammedrashadkm@gmail.com>
Here is GRASS GIS Web UI connected with OpenLayers widget
http://lsi.iiit.ac.in/lsi/wgrass
The app is under development and is released for initial testing. For testing purpose
we fix a lat/lont location and concentrate on vector data
Location Info:
extent -180,-90,180,90
mapset PERMANENT
you can import any grass vector data using v.in.ogr and display it in OL using d.vect
For Listed GRASS modules:
1. Type on search box on top for list and select a module and hit enter or click search
2. you will get a menuForm of the selected GRASS module.
3. Fill all the attributes and click run to execute the grass module.
You can also run any grass command v.* or r.* using this webUI which is unlisted
please test it....
Any comments, suggestions, BUGS are always welcomed..
Thanks && Regards
Rashad
Bhè, sarebbe interessante almeno vedere qualcosa in quella pagina, a me appare vuota ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
giovanni
2011/8/8 Paolo Cavallini <cavallini@faunalia.it>
Interessante, no?
Location Info:
mapset PERMANENT
- Type on search box on top for list and select a module and hit enter or click search
- you will get a menuForm of the selected GRASS module.
- Fill all the attributes and click run to execute the grass module.
please test it…
Any comments, suggestions, BUGS are always welcomed…
Thanks && Regards
Rashad
Iscriviti all’associazione GFOSS.it: http://www.gfoss.it/drupal/iscrizione
Gfoss@lists.gfoss.it
le posizioni dell’Associazione GFOSS.it.
527 iscritti al 7.7.2011
Per ora funziona (es.: carica un file .shp (v.in.ogr) lo visualizzi (d.vect) gli applichi un buffer .. visualizzi la nuova mapp)
è un prof-of-concept ... Mohammed ed io siamo in cerca di sponsors interessati al suo sviluppo .... (hardest part)
si tratta di una verione "light" di grass portata in c++ integrata in webtoolkit,
verrà presto rilasciata sotto gpl.
ciao!
--Massimo.
Il giorno 08/ago/2011, alle ore 10.26, Paolo Cavallini ha scritto:
Interessante, no?
Location Info:
mapset PERMANENT
please test it....
Thanks && Regards
Rashad
Ma la pagina linkata non mostra niente… http://lsi.iiit.ac.in/lsi/wgrass
Il giorno 08 agosto 2011 13:40, Massimo Di Stefano <massimodisasha@gmail.com> ha scritto:
Per ora funziona (es.: carica un file .shp (v.in.ogr) lo visualizzi (d.vect) gli applichi un buffer … visualizzi la nuova mapp)
è un prof-of-concept … Mohammed ed io siamo in cerca di sponsors interessati al suo sviluppo … (hardest part)
si tratta di una verione “light” di grass portata in c++ integrata in webtoolkit,
ciao!
–Massimo.
Interessante, no?
Location Info:
mapset PERMANENT
please test it…
Thanks && Regards
Rashad
Confermo anche a me non da niente
W
Walter Lorenzetti phD
email: [lorenzetti@gis3w.it](mailto:lorenzetti@gis3w.it)
skype: aiki74
Cell: (+39) 347-6597931 Tel+Fax: (+39) 0588 85021
Viale Giuseppe Verdi n. 24, 51016
Montecatini Terme,Pistoia
P.IVA 01686280478
provate ora …
il link è collegato al codice in continuo sviluppo.
probabile che cada di nuovo.
skype: aiki74
P.IVA 01686280478
Il 10/08/2011 10:49, Massimo Di Stefano ha scritto:
provate ora ...
no: provo con v.random, ad es., e il tab Required rimane vuoto.
Cosa intendi con "versione light" e con "portata in c++"?
Grazie.
che non abbiamo implementato tutti i comandi ...
è una test app nata qualche giorno fa, prova con :
v.in.ogr
d.vect
v.buffer
d.vect
ciao.
provate ora ...
Grazie.
ah, ok
scusa se insisto: cosa significa "portata in C++"?
e, di conseguenza: dov'e' il codice?
grazie mille.
GRASS viene “chiamato” da un interfaccia web scritta in c++
il codice verrà presto rilasciato on line su un repository git
ma vogliamo prima mettere su un minimo di esempi/descrizioni etc etc … su un’istanza redmine.
“stay tuned”
il processo richiederà un po di tempo.
Stiamo cercando sponsors che vogliano supportare il progetto,
da qui la necessità di mostrare le potenzialità di tale lavoro.
–Massimo.
(scudo anti squalo attivato)
Il 10/08/2011 12:12, Massimo Di Stefano ha scritto:
GRASS viene "chiamato" da un interfaccia web scritta in c++
interessante; domanda ovvia: perche' non in python?
ma vogliamo prima mettere su un minimo di esempi/descrizioni etc etc .. su un'istanza
redmine.
"stay tuned"
se richiede tempo, il mio consiglio e', come sempre: release early, release often.
Saluti.
