scusate ma non riesco a capire e ad istallare definitivamente alcune cose. mi potete spiegare passo passo in Italiano come fare i passaggi sotto riportati nei TXT.
la cartella /Library/Application Support/GDAL/1.11/Libraries, su mac osx non la trovo assolutamente, potete dirmi per cortesia dove la trovo ? grazie
VERY IMPORTANT POST-INSTALL
You MUST download and install the FileGDB API yourself. Redistribution is hazy in the license, and I don’t have the means to enforce Esri’s export restrictions. I’m sorry, but for now installation is a manual process:
Go to http://www.esri.com/apps/products/download/. Download requires a free registration. Sign in and download the FileGDB API version 1.3.
Unzip the the downloaded zip file.
Move the 2 .dylib files from the lib folder to (the installer creates this folder):
so it looks like (there may be other files in Libraries and PlugIns for other installed plugins):
Library
Application Support
GDAL
1.11
Libraries
libfgdbunixrtl.dylib
libFileGDBAPI.dylib
PlugIns
ogr_FileGDB.dylib
You can trash the unzipped folder when done.
e inoltre VERY IMPORTANT POST-INSTALL
You MUST download and install the ECW SDK yourself. I don’t have the means to enforce export restrictions. I’m sorry, but installation is a manual process for now:
Go to http://download.intergraph.com/download-portal. Select “ERDAS ECW/JPEG2000 SDK” from the Product popup. Click on the MacOSX line, then the Download Now link.
Open the downloaded disk image and run the installer, select the Desktop Read-Only Redistributable license (or Read-Write if you have a full license). It will install into the top of your boot drive, /Hexagon. Dig into this folder to Desktop_Read-Only/redistributable/libstdc++.
Copy the libNCSEcw.dylib file to:
and copy the whole Desktop_Read-Only/etc folder here to (the /Library folder is likely hidden, so you need to Go-Go to Folder from your desktop and type in /Library):
Library
Application Support
GDAL
1.11
etc
Libraries
libNCSEcw.dylib
PlugIns
gdal_ECW_JP2ECW.dylib
You can trash the installed Hexagon folder when done to save a few hundred MB of space.
scusate nuovamente
