Ciao,
qualcuno ha voglia di "sporcarsi" le mani in attesa di un vero supporto kml in
mapserver?
Allego il README.
KML mapserver wrapper
* What is this thing?
this is a php_mapscript wrapper around UNM Mapserver
* Requirements
PHP5 with simplexml and php_mapscript
* Configuration
Configuration is done through CGI-style calls and through some optional
metadata in the mapfile
METADATA:
RESULT_FIELDS # from which field to take the name for the
feature
# defaults to the first field
BALOON_TEMPLATE # if present, this is used for placemark
features
# tooltip. Parameters surrounded by "%" char
are substituted
# with real values from the corresponding field
for the feature
DESCRIPTION # All those metadata are searched (in this
order) to get a layer
OWS_TITLE # description
WFS_TITLE
WMS_TITLE
CGI-PARAMETERS:
* - request = string - optional - request type (OGC WFS like)
* - map = string - required - path to mapfile
* - typename = string - optional - (can be a csv list) - layer name(s),
if empty, all layers are returned
* - filter = string - optional - filter encoding (single layer
requests only)
* - bbox = string - optional - standard bbox specification (Not yet
implemented)
* - encoding = string - optional - default to ISO-8859-1
* Filters
Only PropertyIsEqualTo and PropertyIsLike are supported ATM.
* Encoding
kml is UTF-8, mapfile and attributes could have other encodings, you can set
encoding via request parameter, otherwise ISO-8859-1 is used as default.
* Raster support
Raster layer are supported as standard WMS network links, it is necessary to
add EPSG:4326 to WMS_SRS metadata on all mapfile layers.
Mapfile must be correctly configured as WMS server (i.e. all required
metadata must be set).
* KMZ compressed output
Not yet finished
* Styles and classes
There is limited support for classes and style:
* only one style for each class is parsed, if you have multiple styles in
one class, the values of the last one are used
* only color, outlinecolor, backgroundcolor, symbol, size and width are
parsed
EXAMPLE CALLS
Single layer:
http://localhost/kmlserver/service.php?map=/map/mapfile-ogc.map&typename=sfumo,vngeo_ospitalita
Two layers (one raster and one vector):
http://localhost/kmlserver/service.php?map=/map/mapfile-ogc.map&typename=vngeo_ospitalita
All layers as network links:
ICON SERVER
Returns a PNG icon for a give poin layer/class combination
Example calls:
http://localhost/kmlserver/symbolservice.php?map=/map/mapfile-ogc.map&typename=vngeo_ospitalita&class=Alberghi
If you want transparent icons, set PNG output format to RGBA and IMAGECOLOR to
the transparent color
Alessandro Pasotti
itOpen - "Open Solutions for the Net Age"
w3: www.itopen.it
Linux User# 167502
