Stamani ho provato a reinstallare Metabeta della regione toscana,
ma purtroppo sembra ci siano ancora problemi,
non so se dipendono dall'applicazione o dal mio sistema (Debian lenny):
eugenio@eugenio-desktop:~/download/metabeta/app$ java -jar GeoMetadata.UI.jar
java.security.NoSuchAlgorithmException: Algorithm [PBEWithMD5AndDES] of type [SecretKeyFactory] from provider [gnu.javax.security.auth.callback.GnuCallbacks: name=GNU-CALLBACKS version=2.1] is not found
at gnu.java.security.Engine.getInstance(libgcj.so.90)
at javax.crypto.SecretKeyFactory.getInstance(libgcj.so.90)
at it.terranova.metadata.helpers.SecurityHelper.initialize(SecurityHelper.java:79)
at it.terranova.metadata.helpers.SecurityHelper.(SecurityHelper.java:60)
at it.terranova.metadata.helpers.SecurityHelper.createInstance(SecurityHelper.java:27)
at it.terranova.metadata.helpers.SecurityHelper.getInstance(SecurityHelper.java:41)
at it.terranova.metadata.iso19115.support.DB_User.setPassword(DB_User.java:137)
at it.terranova.metadata.iso19115.support.DB_User.(DB_User.java:54)
at it.terranova.metadata.ui.application.MainForm.(MainForm.java:304)
at java.lang.Class.initializeClass(libgcj.so.90)
Exception in thread "main" java.lang.ExceptionInInitializerError
Caused by: java.lang.IllegalStateException: Security error: initialization failed
at it.terranova.metadata.helpers.SecurityHelper.initialize(SecurityHelper.java:89)
Caused by: java.security.NoSuchAlgorithmException: Algorithm [PBEWithMD5AndDES] of type [SecretKeyFactory] from provider [gnu.javax.security.auth.callback.GnuCallbacks: name=GNU-CALLBACKS version=2.1] is not found
...7 more
Spero l'output possa essere utile...
Eugenio
_________________________________________________________________
Screensaver e sfondi… Scaricali dallo Spaces di Doretta!
https://cid-97b0d995232b954a.skydrive.live.com/home.aspx
GeoMetadata.UI.jar
at
at
at
at
at
failed
at
at
at
at
at
at
...7 more
Eugenio
Gfoss@faunalia.com
http://www.faunalia.com/cgi-bin/mailman/listinfo/gfoss
Prova a lanciarlo da root!
e controlla che la variabile d'ambiente sia settata su
"/usr/lib/jvm/java-6-sun/jre/bin/java"
a me con debian/lenny funziona!
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/Metadata-tp19266255p19387937.html
Sent from the Gfoss mailing list archive at Nabble.com.
L?errore e' che attualmente il java che stai usando e' la gcj
e non la jadk-sun.
E purtroppo il gcj e' compatibile con jdk 1.4 e non con jdk 1.5.
Dopo che hai installato jdk 1.5 o (meglio) jdk 1.6
lo chiami cosi':
ipotizzando che la JDK la hai instalata in /opt/jdk6
/opt/jdk6/bin/java -jar GeoMetadata.UI.jar
(non serve configurare classpath)
e tutto dovrebbe andare.
Grazie per i feedbacks...
Andrea.
2008/9/9 Eugenio Trumpy <frippe12573@hotmail.com>:
...7 more
Eugenio
§ Andrea §
§ Peri §
