Week 6 (July 3, 2009)
- What did I do this week:
Fixed the Grass Raster Rendering in Ossim-Gdal plug-in, now we can load grass raster data type (Byte, Uint16, Float32, Float64) in imagelinker and Ossimplanet.
The rendering works great, all the ossim function like “img2rr, create_histo,
mosaic, image_info …” now works on grass data too. -
Finished to wrote a template mapfile to read gps data in real time (gps data stored on postgis) … i need yet to implement an autogenerated mapfile based on selected
grass layers. -
Create a python dictionary from the geonames cities database (a dictionary for
each region) targhet is to have a combobox with listed region once one region is
selected in an other combobox we’ll have cities names to zoom to. -
Continue to sperimenting the use of r.external read in grass imagery data generated by ossim.
- What do I plan on doing next week:
Study/Learning/experiment with the broadcast/listner Ossimplanet’s capabilities.
(targhet is to load raster data in ossim using tcp connection). -
Learn more on grass command like : r.cost, r.los, v.net.path, v.net.salesman.
the targhet is to generate capture nodes using the gui/joystick pass them to grass
generate visibility-map/route/path and send it out to planet.
- Am I blocked on anything: x
blog page : http://www.geofemengineering.it/epifanio/sasha/sasha/Home.html
