Week 8 (July 18, 2009)
- What did I do this week:
- Implemented a Grass shell in the pyqt gui, (it is a standard unix shell + grass environment). The history is readed directly from the grass history file deleting the duplicated lines and sorting it alfabetically (it is accessible using a combo-box). Some people suggest me to use pyredline directly i’ve sperimented it but i’m more familiar with python list and combo box approach.
- Working to have a better rendering from the grass command that print text-infos about selected layers.
- Rewrite the python’s tool to transfer data from postgresql to spatialite,i re-done a more-informational spatialite-db based on geonames (i included other infos,not only : name , lon, lat values). I’m Planning to add different spatialite-db (examples : one for geonames, one for gps recorded data, an other one for saved points of interest + tool to store points dircty in spatialite) this work will be integrated by routing abilities (using grass command, i’m following with interest the new great Gsoc tool about routing) .
- Bug fixing … continue some linux/osx test, i find that ubuntu 8.10 has a bug in the sdl libraries, this give problems to detetc the “joystick-hat” using pygame. Googling and coding seems i find a walkaround using python-gobject as an alternative way to support joystick instead to use pygame (only for ubuntu8.10). The code to detect hardware is ready but i need to reimplement the joystick code from pygame to, but this is a minor issue, i’ll do it it only if really needed ubuntu8.10 support. (on more recent distro “sidux” all works fine with pygame as on osx, i’ also tried a bit … on windows platform,some adjustment i get the gui loaded and the position message working, but too many dependencies to satysfy (gpsd, pygame…)so i aborted my tests )
- Added a Qdialog to show infos about illegal gui usage, and to manage exceptions. (it is a simply window to show a message if we done some not handled action … like : pan without selecting a pan-mode, connect gps withot existing connection etc…) for now i implemented the gui system but i need to see all the possible exception and change the message according to it.
- What do I plan on doing next week:
- Continue bug fixing, gui cosmetics.
- Recompile ossim using the last svn (thanks to the Dev team some new cool enanchemets are coming
), see if it is possible to fighting against the code to send message trough tcp, i will start to read source code, i hope to be able to learn about the problem that block me to send data-message.
- Am I blocked on anything:
- Continue to read and try to learn the ossim tcp inteface (target: send data using tcp connection).
PS.:
Apologize me for the gap-time to present this report. …
The last week i was out of my home, without computer and internet access.
i had only the google “note-book” (paper) to make annotation about ideas
(they can ever come up … when you don’t know… at every time of the day)
