ciao tutti,
sto cercando di compilare le librerie di pgrouting. Dopo avere installato le librerie di requirements (BGL, GAUL, CGAL) il primo passo di configurazione termina senza errori. Lanciando il make ottengo questo:
/home/sit/src/pgrouting/core/src/dijkstra.c:23:26: error: executor/spi.h: No such file or directory
/home/sit/src/pgrouting/core/src/dijkstra.c:24:21: error: funcapi.h: No such file or directory
/home/sit/src/pgrouting/core/src/dijkstra.c:26:18: error: fmgr.h: No such file or directory
/home/sit/src/pgrouting/core/src/dijkstra.c:30: warning: parameter names (without types) in function declaration
/home/sit/src/pgrouting/core/src/dijkstra.c: In function ‘finish’:
/home/sit/src/pgrouting/core/src/dijkstra.c:63: error: ‘SPI_OK_FINISH’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:63: error: (Each undeclared identifier is reported only once
/home/sit/src/pgrouting/core/src/dijkstra.c:63: error: for each function it appears in.)
/home/sit/src/pgrouting/core/src/dijkstra.c: At top level:
/home/sit/src/pgrouting/core/src/dijkstra.c:81: error: expected ‘)’ before ‘’ token
/home/sit/src/pgrouting/core/src/dijkstra.c:136: error: expected ‘)’ before ‘’ token
/home/sit/src/pgrouting/core/src/dijkstra.c: In function ‘compute_shortest_path’:
/home/sit/src/pgrouting/core/src/dijkstra.c:181: error: ‘Portal’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:181: error: expected ‘;’ before ‘SPIportal’
/home/sit/src/pgrouting/core/src/dijkstra.c:201: error: ‘SPI_OK_CONNECT’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:207: warning: assignment makes pointer from integer without a cast
/home/sit/src/pgrouting/core/src/dijkstra.c:214: error: ‘SPIportal’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:226: error: ‘SPI_tuptable’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:231: error: ‘SPI_processed’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:247: error: ‘SPITupleTable’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:247: error: ‘tuptable’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:248: error: ‘TupleDesc’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:248: error: expected ‘;’ before ‘tupdesc’
/home/sit/src/pgrouting/core/src/dijkstra.c:252: error: ‘HeapTuple’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:252: error: expected ‘;’ before ‘tuple’
/home/sit/src/pgrouting/core/src/dijkstra.c:253: error: ‘tuple’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:253: error: ‘tupdesc’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:353: warning: data definition has no type or storage class
/home/sit/src/pgrouting/core/src/dijkstra.c:353: warning: parameter names (without types) in function declaration
/home/sit/src/pgrouting/core/src/dijkstra.c: In function ‘shortest_path’:
/home/sit/src/pgrouting/core/src/dijkstra.c:357: error: ‘FuncCallContext’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:357: error: ‘funcctx’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:360: error: ‘TupleDesc’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:360: error: expected ‘;’ before ‘tuple_desc’
/home/sit/src/pgrouting/core/src/dijkstra.c:377: warning: passing argument 1 of ‘text2char’ makes pointer from integer without a cast
/home/sit/src/pgrouting/core/src/dijkstra.c:411: error: ‘tuple_desc’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:416: error: ‘HeapTuple’ undeclared (first use in this function)
/home/sit/src/pgrouting/core/src/dijkstra.c:416: error: expected ‘;’ before ‘tuple’
/home/sit/src/pgrouting/core/src/dijkstra.c:446: error: ‘tuple’ undeclared (first use in this function)
make[2]: *** [core/src/CMakeFiles/routing.dir/dijkstra.o] Error 1
make[1]: *** [core/src/CMakeFiles/routing.dir/all] Error 2
make: *** [all] Error 2
Sembra non trovi alcune librerie (spi.h, funcapi.h) che sono presenti comunque nella directory di podtgresql indicata nel file di config…non capisco dove altro agire per impostare in maniera corretta.
Qualcun altro ha avuto esperienza con debian Lenny?
Grazie per qualsiasi suggerimento
flavio
Linux, perche’ no? Io uso debian.
