Ciao a tutti…
da un minuto all’altro pyuic4 non ne vuole più sapere di aggiornarmi le gui da .ui a .py.
L’errore che ricevo è questo[1]
Qualcuno sa darmi qualche dritta???
Ciao e grazie mille!
Luca
[1]
Dynamic:gui pyarchinit$ pyuic4 myDialog_ui.py -o myDialog_ui.ui
An unexpected error occurred.
Check that you are using the latest version of PyQt and send an error report to
support@riverbankcomputing.com, including the following information:
- your version of PyQt (snapshot-4.8.6-4726879563e5)
- the UI file that caused this error
- the debug output of pyuic4 (use the -d flag when calling pyuic4)
host128-242-dynamic:gui pyarchinit$ pyuic4 pyarchinit_Site_ui.py -o pyarchinit_Site_ui.ui -d
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/port_v2/invoke.py”, line 39, in invoke
exit_status = driver.invoke()
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/driver.py”, line 64, in invoke
self._generate()
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/driver.py”, line 98, in _generate
self._opts.pyqt3_wrapper, self._opts.from_imports)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/init.py”, line 170, in compileUi
winfo = compiler.UICompiler().compileUi(uifile, pyfile, from_imports)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/Compiler/compiler.py”, line 119, in compileUi
w = self.parse(input_stream)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/uiparser.py”, line 919, in parse
document = parse(filename)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/etree/ElementTree.py”, line 862, in parse
tree.parse(source, parser)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/etree/ElementTree.py”, line 586, in parse
parser.feed(data)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/etree/ElementTree.py”, line 1245, in feed
self._parser.Parse(data, 0)
ExpatError: not well-formed (invalid token): line 1, column 1
Ciao Luca,
hai invertito input e l'output ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Se sei stato fortunato allora dopo aver eseguito
ti ritrovi il file .ui senza modifiche, altrimenti (e anche probabilmente)
te lo ritroverai vuoto.
Saluti.
2011/9/20 Luca Mandolesi <mandoluca@gmail.com>:
Ciao a tutti...
da un minuto all'altro pyuic4 non ne vuole più sapere di aggiornarmi le gui
da .ui a .py.
L'errore che ricevo è questo[1]
Luca
[1]
to
* your version of PyQt (snapshot-4.8.6-4726879563e5)
* the UI file that caused this error
* the debug output of pyuic4 (use the -d flag when calling pyuic4)
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/port_v2/invoke.py",
line 39, in invoke
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/driver.py",
line 64, in invoke
self._generate()
File
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/__init__.py",
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/Compiler/compiler.py",
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/PyQt4/uic/uiparser.py",
line 919, in parse
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/etree/ElementTree.py",
line 862, in parse
File
line 586, in parse
parser.feed(data)
File
line 1245, in feed
Gfoss@lists.gfoss.it
527 iscritti al 7.7.2011
Giuseppe Sucameli
Che vergogna…devo smettere di lavorare la sera…son 2 giorni che aggiorno facendo lo stesso errore…ero su una copia…sta bon!
Ciao e grazie
Luca
On Tue, Sep 20, 2011 at 10:54 PM, Giuseppe Sucameli <sucameli@faunalia.it> wrote:
Ciao Luca,
hai invertito input e l’output ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Saluti.
Ciao a tutti…
da .ui a .py.
Luca
[1]
to
File
line 39, in invoke
File
line 64, in invoke
self._generate()
File
File
File
File
line 919, in parse
File
line 862, in parse
File
line 586, in parse
parser.feed(data)
File
line 1245, in feed
Iscriviti all’associazione GFOSS.it: http://www.gfoss.it/drupal/iscrizione
le posizioni dell’Associazione GFOSS.it.
Giuseppe Sucameli
