Salve a tutti,
come mai se lancio il comando>ls da dentro R (già dentro il mapset di grass) ottengo:
ls
function (name, pos = -1, envir = as.environment(pos), all.names = FALSE,
pattern)
if (!missing(name)) {
nameValue <- try(name)
if (identical(class(nameValue), "try-error")) {
name <- substitute(name)
if (!is.character(name))
name <- deparse(name)
pos <- name
else pos <- nameValue
all.names <- .Internal(ls(envir, all.names))
if (!missing(pattern)) {
if ((ll <- length(grep("[", pattern, fixed = TRUE)))>
0 && ll != length(grep("]", pattern, fixed = TRUE))) {
if (pattern == "[") {
pattern <- "\\["
warning("replaced regular expression pattern '[' by '\\\\['")
else if (length(grep("[^\\\\]\\[<-", pattern)> 0)) {
pattern <- sub("\\[<-", "\\\\\\[<-", pattern)
warning("replaced '[<-' by '\\\\[<-' in regular expression pattern")
grep(pattern, all.names, value = TRUE)
else all.names
Eugenio
_________________________________________________________________
Curiosità, trucchi e consigli per il tuo Messenger!
http://www.messenger.it
system("ls"): http://stat.ethz.ch/R-manual/R-patched/library/base/html/system.html
Il prompt di R non è un terminale bash. Quando lanci R entri nel suo
ambiente di scripting, percui devi usare il suo linguaggio.
2008/7/21 Eugenio Trumpy <frippe12573@hotmail.com>:
Salve a tutti,
ls
pattern)
pos <- name
pattern <- "\\["
else all.names
Eugenio
Gfoss@faunalia.com
http://www.faunalia.com/cgi-bin/mailman/listinfo/gfoss
