Eugenio Trumpy ha scritto:
io ho riprovato dopo aver seguito il tuo consiglio,
ho rimosso la libqgis-0.11 che in effetti era ancora installata,
adesso ho solo la libqgis-1.0.0
ma il problema sembra persistere...
l'output è questo:
Warning: QgsComposerItem::mouseMoveEvent
Warning: 2
Warning: Object::disconnect: Unexpected null parameter
Fatal: ASSERT failure in QList<T>::at: "index out of range", file
/usr/include/qt4/QtCore/qlist.h, line 387
Abortito
Che qt avete? Io ho questi, tutti da debian testing:
i A libqt4-assistant - Qt 4 assistant module
i libqt4-core - transitional package for Qt 4 core
non-GUI
i A libqt4-dbus - Qt 4 D-Bus module
i A libqt4-designer - Qt 4 designer module
i libqt4-dev - Qt 4 development files
i libqt4-gui - transitional package for Qt 4 GUI
runtime
i A libqt4-help - Qt 4 help module
i A libqt4-network - Qt 4 network module
i A libqt4-opengl - Qt 4 OpenGL module
i A libqt4-opengl-dev - Qt 4 OpenGL library development
files
i libqt4-qt3support - Qt 3 compatibility library for Qt
4
i A libqt4-script - Qt 4 script module
i libqt4-sql - Qt 4 SQL module
i A libqt4-sql-mysql - driver Qt 4 per database MySQL
i A libqt4-sql-sqlite - Qt 4 SQLite 3 database driver
i A libqt4-svg - Qt 4 SVG module
i A libqt4-test - Qt 4 test module
i A libqt4-webkit - Qt 4 WebKit module
i A libqt4-xml - Qt 4 XML module
i A libqt4-xmlpatterns - Qt 4 XML patterns module
i libqwt5-qt4 - Qt4 widgets library for technical
applicat
i A libqwt5-qt4-dev - Qt4 widgets library for technical
applicat
i lsb-qt4 - Linux Standard Base 3.2 Qt4
support packag
i python-qt4 - Python bindings for Qt4
i A python-qt4-common - Shared files for PyQt4
i A python-qt4-dbus - DBus Support for PyQt4
i python-qt4-dev - Development files for PyQt4
i python-qwt5-qt4 - Python version of the Qwt5
technical widge
i qt4-designer - graphical designer for Qt 4
applications
i qt4-dev-tools - Qt 4 development tools
i A qt4-doc - Qt 4 API documentation
i A qt4-qmake - Qt 4 qmake Makefile generator tool
i qt4-qtconfig - Qt 4 configuration tool
Se la cosa persiste, merita segnalarla in ML o meglio sul trac.
Saluti.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
