Ciao a tutti,
Quando provo a caricare un vettoriale di grass da qgis 0.10
succede che esce immediatamente con con questo output:
pitta1981@zolfo:~$ qgis
Warning: No valid projection. Unable to set map units.
Warning: QgsSpatialRefSys::getRecord failed : select * from
tbl_srs where parameters='+proj=longlat +a=6378137
+b=6356733,855704698 +datum=WGS84 +no_defs'
Warning: QgsSpatialRefSys::findMatchingProj will only work
if prj acr ellipsoid acr and proj4string are set!...
Loaded /usr/lib/qgis/libcopyrightlabelplugin.so
Loaded /usr/lib/qgis/libdelimitedtextplugin.so
Loaded /usr/lib/qgis/libdelimitedtextprovider.so
Loaded /usr/lib/qgis/libgeorefplugin.so
Loaded /usr/lib/qgis/libgpsimporterplugin.so
Loaded /usr/lib/qgis/libgpxprovider.so
Loaded /usr/lib/qgis/libgrassplugin.so
Loaded /usr/lib/qgis/libgrassprovider.so
Loaded /usr/lib/qgis/libgridmakerplugin.so
Loaded /usr/lib/qgis/libnortharrowplugin.so
Loaded /usr/lib/qgis/libogrprovider.so
Loaded /usr/lib/qgis/libpggeoprocessingplugin.so
Loaded /usr/lib/qgis/libpostgresprovider.so
Loaded /usr/lib/qgis/libquickprintplugin.so
Loaded /usr/lib/qgis/libscalebarplugin.so
Loaded /usr/lib/qgis/libspitplugin.so
Loaded /usr/lib/qgis/libwfsplugin.so
Loaded /usr/lib/qgis/libwfsprovider.so
Loaded /usr/lib/qgis/libwmsprovider.so
<module 'mapserver_export' from
'/usr/share/qgis/python/plugins/mapserver_export/__init__.pyc'>
<module 'plugin_installer' from
'/usr/share/qgis/python/plugins/plugin_installer/__init__.pyc'>
getting list of plugins
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
QgsGrass::vectors()
error_routine (fatal = 1): default region is invalid
line 9: <e-w resol: 5.3>
Cannot open GRASS vector: default region is invalid
*** stack smashing detected ***: qgis terminated
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb6405138]
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x0)[0xb64050f0]
/usr/lib/qgis/libgrassplugin.so[0xb2649414]
/usr/lib/qgis/libgrassplugin.so(_ZN14QgsGrassSelect12vectorLayersE7QStringS0_S0_S0_+0x704)[0xb25684a4]
/usr/lib/grass/lib/libgrass_gis.so[0xb249dd23]
======= Memory map: ========
08048000-082ac000 r-xp 00000000 08:03 1035648
/usr/bin/qgis
082ac000-082af000 rw-p 00263000 08:03 1035648
/usr/bin/qgis
082af000-093ce000 rw-p 082af000 00:00 0 [heap]
b0ba7000-b0bff000 rw-p b0ba7000 00:00 0
b0bff000-b0c00000 ---p b0bff000 00:00 0
b0c00000-b144f000 rw-p b0c00000 00:00 0
b144f000-b1500000 ---p b144f000 00:00 0
b150d000-b15d2000 rw-p b150d000 00:00 0
b15d2000-b1605000 r-xp 00000000 08:03 1197791
/usr/lib/python2.5/lib-dynload/pyexpat.so
b1605000-b1608000 rw-p 00033000 08:03 1197791
b1608000-b160c000 r-xp 00000000 08:03 7652423
/lib/tls/i686/cmov/libnss_dns-2.7.so
b160c000-b160e000 rw-p 00003000 08:03 7652423
b1653000-b16d7000 rw-p b1653000 00:00 0
b16d7000-b16d9000 r-xp 00000000 08:03 7620067
/lib/libnss_mdns4_minimal.so.2
b16d9000-b16da000 rw-p 00001000 08:03 7620067
b16fa000-b16fe000 r-xp 00000000 08:03 1196253
/usr/lib/python2.5/lib-dynload/zlib.so
b16fe000-b16ff000 rw-p 00004000 08:03 1196253
b16ff000-b1702000 r-xp 00000000 08:03 1196216
/usr/lib/python2.5/lib-dynload/cStringIO.so
b1702000-b1703000 rw-p 00003000 08:03 1196216
b1703000-b1708000 r-xp 00000000 08:03 1196210
/usr/lib/python2.5/lib-dynload/_struct.so
b1708000-b1709000 rw-p 00005000 08:03 1196210
b1709000-b170c000 r-xp 00000000 08:03 1196228
/usr/lib/python2.5/lib-dynload/fcntl.so
b170c000-b170d000 rw-p 00003000 08:03 1196228
b170d000-b170f000 r-xp 00000000 08:03 1196202
/usr/lib/python2.5/lib-dynload/_random.so
b170f000-b1710000 rw-p 00002000 08:03 1196202
b1710000-b1714000 r-xp 00000000 08:03 1196220
/usr/lib/python2.5/lib-dynload/binascii.so
b1714000-b1715000 rw-p 00003000 08:03 1196220
b1715000-b1718000 r-xp 00000000 08:03 1196249
/usr/lib/python2.5/lib-dynload/time.so
b1718000-b171a000 rw-p 00002000 08:03 1196249
b171a000-b1725000 r-xp 00000000 08:03 1196204
/usr/lib/python2.5/lib-dynload/_socket.so
b1725000-b1728000 rw-p 0000a000 08:03 1196204
b1728000-b172f000 r-xp 00000000 08:03 2511517
/usr/lib/gdalplugins/gdal_GRASS.so
b172f000-b1730000 rw-p 00006000 08:03 2511517
b1730000-b17a2000 r-xp 00000000 08:03 1656705
/usr/lib/python2.5/site-packages/qgis/gui.so
b17a2000-b17a8000 rw-p 00072000 08:03 1656705
b17a8000-b17f7000 r-xp 00000000 08:03 2277476
/usr/lib/python2.5/site-packages/PyQt4/QtXml.so
b17f7000-b17fd000 rw-p 0004f000 08:03 2277476
b17fd000-b18a5000 r-xp 00000000 08:03 1656703
/usr/lib/python2.5/site-packages/qgis/core.so
b18a5000-b18b2000 rw-p 000a8000 08:03 1656703
b18b2000-b1f03000 r-xp 00000000 08:03 2277470
/usr/lib/python2.5/site-packages/PyQt4/QtGui.so
b1f03000-b1f65000 rw-p 00650000 08:03 2277470
b1f65000-b20bc000 r-xp 00000000 08:03 2277469
/usr/lib/python2.5/site-packages/PyQt4/QtCore.so
b20bc000-b20dc000 rw-p 00157000 08:03 2277469
b20dc000-b20eb000 r-xp 00000000 08:03 1197219
/usr/lib/python2.5/site-packages/sip.so
b20eb000-b20ec000 rw-p 0000f000 08:03 1197219
b20ec000-b212d000 rw-p b20ec000 00:00 0
b212d000-b215f000 r-xp 00000000 08:03 1656684
b215f000-b2160000 rw-p 00031000 08:03 1656684
b2160000-b2180000 r-xp 00000000 08:03 1656698
b2180000-b2181000 rw-p 0001f000 08:03 1656698
b2181000-b219a000 r-xp 00000000 08:03 1656701
b219a000-b219b000 rw-p 00019000 08:03 1656701
b219b000-b21d4000 r-xp 00000000 08:03 1656681
b21d4000-b21d6000 rw-p 00039000 08:03 1656681
b21d6000-b2208000 r-xp 00000000 08:03 1656696
b2208000-b2209000 rw-p 00032000 08:03 1656696
b2209000-b221a000 r-xp 00000000 08:03 1656692
b221a000-b221b000 rw-p 00011000 08:03 1656692
b221b000-b225d000 r-xp 00000000 08:03 1656674
b225d000-b225e000 rw-p 00041000 08:03 1656674
b225e000-b233e000 r-xp 00000000 08:03 4326275
/usr/lib/libfftw3.so.3.1.2
b233e000-b2344000 rw-p 000e0000 08:03 4326275
b2344000-b2371000 r-xp 00000000 08:03 7618602
/lib/libncurses.so.5.6
b2371000-b2374000 rw-p 0002c000 08:03 7618602
b2374000-b2379000 r-xp 00000000 08:03 1689048
/usr/lib/grass/lib/libgrass_gmath.6.3.0.so
b2379000-b237a000 rw-p 00004000 08:03 1689048
b237a000-b2384000 r-xp 00000000 08:03 1689052
/usr/lib/grass/lib/libgrass_I.6.3.0.so
b2384000-b2385000 rw-p 00009000 08:03 1689052
b2385000-b2388000 r-xp 00000000 08:03 1196236
/usr/lib/python2.5/lib-dynload/math.so
b2388000-b2389000 rw-p 00002000 08:03 1196236
b2389000-b238d000 r-xp 00000000 08:03 1196244
/usr/lib/python2.5/lib-dynload/strop.so
b238d000-b238f000 rw-p 00004000 08:03 1196244
b238f000-b23a4000 r-xp 00000000 08:03 1656700
b23a4000-b23a5000 rw-p 00014000 08:03 1656700
b23a5000-b23af000 r-xp 00000000 08:03 2511518
/usr/lib/gdalplugins/ogr_GRASS.so
b23af000-b23b0000 rw-p 00009000 08:03 2511518
b23b0000-b23dd000 r-xp 00000000 08:03 1656691
b23dd000-b23de000 rw-p 0002d000 08:03 1656691
b23de000-b2407000 r-xp 00000000 08:03 1656697
b2407000-b2408000 rw-p 00029000 08:03 1656697
b2408000-b2410000 r-xp 00000000 08:03 1689022
/usr/lib/grass/lib/libgrass_gproj.6.3.0.so
b2410000-b2411000 rw-p 00007000 08:03 1689022
b2411000-b2414000 r-xp 00000000 08:03 1689012
/usr/lib/grass/lib/libgrass_form.6.3.0.so
b2414000-b2415000 rw-p 00002000 08:03 1689012
b2415000-b241c000 r-xp 00000000 08:03 1689044
/usr/lib/grass/lib/libgrass_datetime.6.3.0.so
b241c000-b241d000 rw-p 00006000 08:03 1689044
b241d000-b2431000 r-xp 00000000 08:03 1689028
/usr/lib/grass/lib/libgrass_dgl.6.3.0.so
b2431000-b2432000 rw-p 00013000 08:03 1689028
b2432000-b2439000 r-xp 00000000 08:03 1689053
/usr/lib/grass/lib/libgrass_shape.6.3.0.so
b2439000-b243a000 rw-p 00006000 08:03 1689053
b243a000-b2447000 r-xp 00000000 08:03 1689017
/usr/lib/grass/lib/libgrass_dbmibase.6.3.0.so
b2447000-b2448000 rw-p 0000c000 08:03 1689017
b2448000-b2450000 r-xp 00000000 08:03 1689049
/usr/lib/grass/lib/libgrass_dbmiclient.6.3.0.so
b2450000-b2451000 rw-p 00007000 08:03 1689049
b2451000-b2462000 r-xp 00000000 08:03 1689021
/usr/lib/grass/lib/libgrass_dig2.6.3.0.so
b2462000-b2463000 rw-p 00010000 08:03 1689021
b2463000-b2493000 r-xp 00000000 08:03 1689011
/usr/lib/grass/lib/Aborted
pitta1981@zolfo:~$
Questa versione è quella installata dai repository per
ubuntu di qgis e grass è la versione installata dai
repository indicati dal sito ufficiale di grass.
Grazie per ogni aiuto.
Simone
