Ora non mi da più l'errore però non succede nulla, ciò se provo a
collegarmi a geoserver mi da errore. mi sembra che nello script non ci
sia nulla che richiami al mio path dove ci sono startup.sh e
shutdown.sh, mi sbaglio o no?
#! /bin/sh
### BEGIN INIT INFO
# Provides: geoserver
# Required-Start: startup.sh
# Required-Stop: shutdown,sh
# Default-Start: 2 3 4 5
# Default-Stop: S 0 1 6
# Short-Description: GeoServer WMS/WFS server
# Description: Java based application for serving OGC compliant
web services.
### END INIT INFO
# Author: Amos Hayes <ahayes@gcrc.carleton.ca>
# Do NOT "set -e"
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/usr/sbin:/usr/bin:/sbin:/bin
DESC="geoserver"
NAME=geoserver
SCRIPTNAME=/etc/init.d/$NAME
## Replace these with the values for your installation
GEOSERVER_USER=luca
GEOSERVER_DATA_DIR=/usr/local/geoserver-1.7.0/data_dir
JAVA_HOME=/usr/lib/jvm/java-6-sun
GEOSERVER_HOME=/usr/local/geoserver-1.7.0/
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Load the VERBOSE setting and other rcS variables
[ -f /etc/default/rcS ] && . /etc/default/rcS
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
. /lib/lsb/init-functions
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
echo `date` >> $GEOSERVER_DATA_DIR/serverlog
cd "$GEOSERVER_HOME"
su "$GEOSERVER_USER" -c "$JAVA_HOME/bin/java
-DGEOSERVER_DATA_DIR=$GEOSERVER_DATA_DIR -Djava.awt.headless=true
-DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar >>
$GEOSERVER_DATA_DIR/serverlog 2>&1 &"
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
su "$GEOSERVER_USER" -c "$JAVA_HOME/bin/java -DSTOP.PORT=8079
-DSTOP.KEY=geoserver -jar start.jar --stop >>
$GEOSERVER_DATA_DIR/serverlog 2>&1"
case "$?" in
esac
echo "Usage: $SCRIPTNAME {start|stop}" >&2
exit 3
esac
ciao
Luca
