Dunque dentro a qgis 1.7 trunk per mac os x, non c’è pyspatialite…ma magari lo metteranno.
Ho provato ad installare su mac os x 10.5 leopard pyspatilite via easy_install, ma ricevo questo errore [1]
Ho provato poi a installare da sorgente ma mi becco questi errori qua [2].
Suggerimenti???
Ciao e grazie.
Luca
[1]
host138-244-dynamic:~ pyarchinit$ sudo easy_install pyspatialite
Password:
Searching for pyspatialite
Reading http://pypi.python.org/simple/pyspatialite/
Reading http://pyspatialite.googlecode.com/
Reading http://code.google.com/p/pyspatialite/downloads/list
Best match: pyspatialite 2.6.1
Downloading http://pyspatialite.googlecode.com/files/pyspatialite-2.6.1.tar.gz
Processing pyspatialite-2.6.1.tar.gz
Running pyspatialite-2.6.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-dmMEmW/pyspatialite-2.6.1/egg-dist-tmp-5T2Y4D
Downloading amalgation.
Extracting sqlite3.c
Extracting headers/spatialite/sqlite3.h
Extracting spatialite.c
Extracting headers/spatialite/sqlite3ext.h
Extracting headers/spatialite/spatialite.h
Extracting headers/spatialite/gaiaaux.h
Extracting headers/spatialite/gaiaexif.h
Extracting headers/spatialite/gaiageo.h
amalgamation/spatialite.c:85:20: amalgamation/spatialite.c:85:20: error: geos_c.h: No such file or directory
amalgamation/spatialite.c:89:22: error: proj_api.h: No such file or directory
amalgamation/spatialite.c: In function ‘gaiaConvertCharset’:
amalgamation/spatialite.c:7557: warning: passing argument 2 of ‘libiconv’ from incompatible pointer type
amalgamation/spatialite.c: In function ‘gaiaConvertToUTF8’:
amalgamation/spatialite.c:7612: warning: passing argument 2 of ‘libiconv’ from incompatible pointer type
amalgamation/spatialite.c: In function ‘gaiaGeomCollEquals’:
amalgamation/spatialite.c:12999: error: ‘GEOSGeometry’ undeclared (first use in this function)
amalgamation/spatialite.c:12999: error: (Each undeclared identifier is reported only once
amalgamation/spatialite.c:12999: error: for each function it appears in.)
amalgamation/spatialite.c:12999: error: ‘g1’ undeclared (first use in this function)
amalgamation/spatialite.c:13000: error: ‘g2’ undeclared (first use in this function)
amalgamation/spatialite.c: In function ‘gaiaGeomCollIntersects’:
amalgamation/spatialite.c:13022: error: ‘GEOSGeometry’ undeclared (first use in this function)
amalgamation/spatialite.c:13022: error: ‘g1’ undeclared (first use in this function)
amalgamation/spatialite.c:13023: error: ‘g2’ undeclared (first use in this function)
amalgamation/spatialite.c: In function ‘gaiaGeomCollDisjoint’:
[2]
host138-244-dynamic:pyspatialite-2.6.1 pyarchinit$ sudo python setup.py install
running install
running build
running build_py
creating build
creating build/lib.macosx-10.3-fat-2.5
creating build/lib.macosx-10.3-fat-2.5/pyspatialite
copying lib/init.py → build/lib.macosx-10.3-fat-2.5/pyspatialite
copying lib/dbapi2.py → build/lib.macosx-10.3-fat-2.5/pyspatialite
copying lib/dump.py → build/lib.macosx-10.3-fat-2.5/pyspatialite
creating build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/init.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/dbapi.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/dump.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/factory.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/hooks.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/regression.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/transactions.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/types.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
copying lib/test/userfunctions.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test
creating build/lib.macosx-10.3-fat-2.5/pyspatialite/test/py25
copying lib/test/py25/init.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test/py25
copying lib/test/py25/py25tests.py → build/lib.macosx-10.3-fat-2.5/pyspatialite/test/py25
running build_ext
building ‘pyspatialite._spatialite’ extension
creating build/temp.macosx-10.3-fat-2.5
creating build/temp.macosx-10.3-fat-2.5/src
creating build/temp.macosx-10.3-fat-2.5/amalgamation
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/module.c -o build/temp.macosx-10.3-fat-2.5/src/module.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/connection.c -o build/temp.macosx-10.3-fat-2.5/src/connection.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/cursor.c -o build/temp.macosx-10.3-fat-2.5/src/cursor.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/cache.c -o build/temp.macosx-10.3-fat-2.5/src/cache.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/microprotocols.c -o build/temp.macosx-10.3-fat-2.5/src/microprotocols.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/prepare_protocol.c -o build/temp.macosx-10.3-fat-2.5/src/prepare_protocol.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/statement.c -o build/temp.macosx-10.3-fat-2.5/src/statement.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/util.c -o build/temp.macosx-10.3-fat-2.5/src/util.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c src/row.c -o build/temp.macosx-10.3-fat-2.5/src/row.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c amalgamation/sqlite3.c -o build/temp.macosx-10.3-fat-2.5/amalgamation/sqlite3.o
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -DMODULE_NAME=“spatialite.dbapi2” -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -Iamalgamation -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -c amalgamation/spatialite.c -o build/temp.macosx-10.3-fat-2.5/amalgamation/spatialite.o
