Ciao,
(dopo aver letto, spero con la dovuta attenzione, le istruzioni per l'installazione) ho provato ad installare la 2.0.1 di QGIS su Ubuntu (Precise).
All'apparire dello "splash screen" di Dufour, "Checking database",
compare un "error dialog" contenente il msg in oggetto.
Dopo questo compare un "phyton error":
Couldn't load plugin processing due an error when calling its classFactory() method
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/usr/share/qgis/python/plugins/processing/__init__.py", line 33, in classFactory
return ProcessingPlugin(iface)
File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py", line 53, in __init__
Processing.initialize()
File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 127, in initialize
Processing.addProvider(RAlgorithmProvider())
File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 75, in addProvider
provider.initializeSettings()
File "/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py", line 51, in initializeSettings
ProcessingConfig.addSetting(Setting(self.getDescription(), RUtils.RSCRIPTS_FOLDER, "R Scripts folder", RUtils.RScriptsFolder()))
File "/usr/share/qgis/python/plugins/processing/r/RUtils.py", line 55, in RScriptsFolder
mkdir(folder)
File "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py", line 95, in mkdir
mkdir(head)
File "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py", line 97, in mkdir
os.mkdir(newdir)
OSError: [Errno 13] Permesso negato: '/home/gis/.qgis2//processing'
Python version:
2.7.3 (default, Apr 10 2013, 06:31:07)
[GCC 4.6.3]
QGIS version:
2.0.1-Dufour Dufour, exported
Python path: ['/usr/share/qgis/python/plugins/processing', '/usr/share/qgis/python', '/home/gis/.qgis2/python', '/home/gis/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/ubuntuone-client', '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel', '/usr/lib/python2.7/dist-packages/ubuntuone-couch', '/usr/lib/python2.7/dist-packages/ubuntuone-installer', '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
Qualche suggerimento?
Grazie!
Ciao,
Francesco.
