-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Salve.
Un plugin credo molto utile, per visualizzare e stampare varie combinazioni dei layer
caricati in un progetto.
Saluti.
- -------- Messaggio originale --------
Mittente: Olivier Dalang <olivier.dalang@gmail.com>
I've been working on a python plugin called "Layer Combinations", which I'd love to
release as stable for QGIS 2.0 (it's still flagged as experimental).
Since it's a workflow enhancement plugin, I thought it could be of some interest to
most of you. If so, I invite you to try the latest version (0.8, requires QGIS
nightly/master), and report any bugs or ideas on the tracker :
https://github.com/olivierdalang/layerCombinations
You'll find a small explanation of the plugin below, and a video trailer here :
https://vimeo.com/70446444
Thanks for your attention !
Olivier
##ᅡ LayerCombinations##
It allows to store the visibility and the folding state of the layers in the legend
in so called "combinations".
Those combination can then be restored, allowing to switch back and forth complex setups.
The combinations can also be applied to composer maps. The link is dynamic, which
means that if the combination is updated, the composer map will automatically reflect
the modifications.
I find it very handy for big projects with many layers and several print composers.
Hope you like it !
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlHniSoACgkQ/NedwLUzIr6WZQCdH32WjUlUzE7B0EC2EL/IaFmV
WXAAmgLf802GApwyt7F1Bp2N/BvXs+e3
=ItR9
-----END PGP SIGNATURE-----
