sulle altre non presenti (nello specifico le spacelib del CRS4 e tinyxml) ho provveduto a compilare e installare.
Sono pero' fermo ad un errore che mi da il compilatore g++
al punto 3 del "HOW TO INSTALL RATMAN"
Nello specifico
g++ -c -pipe -O3 -ffast-math -D_REENTRANT -Wall -W -fPIC -DNDEBUG -D__LIB64__ -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4 -I. -I../../../src -I. -I../../../src -I/usr/local/include -I/usr/include -I/usr/include -IRelease -o Release/curlstream.o curlstream.cpp
In file included from curlstream.cpp:1:
curlstream.hpp:57: error: ‘EOF’ was not declared in this scope
con un hack malsano (= senza capire a fondo cosa volesse dire) ho superato il problema (= ho sostituito 'EOF' con un valore numerico alto)
Questa cosa malsana mi permette di passare al punto 4, ma qui ottengo un altro errore a cui mi fermo vista la nefandezza precedente.
In questo caso e' mpiCC ad arrabbiarsi
mpiCC -c -pipe -O3 -ffast-math -O3 -D_REENTRANT -Wall -W -fPIC -DNDEBUG -D__LIB64__ -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_ISOC9X_SOURCE=1 -D_ISOC99_SOURCE=1 -D__USE_ISOC9X=1 -D__USE_ISOC99=1 -D_ISOC9X_SOURCE=1 -D_ISOC99_SOURCE=1 -D__USE_ISOC9X=1 -D__USE_ISOC99=1 -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4 -I. -I../../../../src -I/usr/local/include -I/usr/local//include/ -I/usr/include/gdal -I/usr/local//include/ -IRelease -o Release/quad_builder.o quad_builder.cpp
quad_builder.cpp: In member function ‘virtual void vic::geo::quad_builder::out_quad_index_write(int, int, int)’:
quad_builder.cpp:108: error: ‘uint64_t’ was not declared in this scope
quad_builder.cpp:108: error: expected ‘;’ before ‘timestamp’
quad_builder.cpp:110: error: ‘timestamp’ was not declared in this scope
Idee? Suggerimenti? Qualche libreria "troppo nuova" ?
Nello specifico
alto)
Orrore! Al limite EOF e' -1 ma comunque manca io aggiungerei
#include <cstdio>
e magari cambiarei l'inclusione di string.h in cstring, se il codice
che guardo e' lo stesso.
precedente.
quad_builder.cpp
Grazie
Qua ci vorrebbe un
#include <stdint.h>
al posto giusto, il dove e' lasciato per esercizio...
