Buongiorno a tutti
sono nuovo del mondo opengis e un pò arruginito sulle basi.
ho questo piccolo problema utilizzando qgis da penna usb con windows . ho trovato questo howto:
Re: Plotting Addresses to street files?
Postby therodabides on Wed Feb 04, 2009 2:32 am
My friend Steve sent me instructions on how to accomplish this,
www.stevevance.net
To get "batch geocoding" in QGIS:
1. Go to Plugins>Manage Plugins
2. Check the checkbox next to "Add Delimited Text Layer"
3. Click Okay to add the plugin to your QGIS
Now you're ready to do your batch geocoding which you'll import into QGIS.
1. In an Excel document, create the following columns in a header row (at a minimum): address, city, state. Other fields you can use: description, name, url, zip, image url
2. Input your data into the appropriate columns
3. Save the Excel document as a Tab Delimited Text file.
4. Open the newly created Tab Delimited Text file in a text-only editor (like Notepad for Windows, TextEdit for Mac, or vi for Linux). Select all the text (including the headers) and copy to clipboard
5. Go to www.batchgeocode.com
6. In the first text field, paste your text
7. Click the Validate Source button
8. In Step 4 on the website, map the columns from your text to their appropriate fields in all the drop down boxes
9. When you're done selecting the options, click Run Geocoder.
10. Copy your now geocoded data back into your text-only editor and save as a new file
Now you're ready to import this geocoded data into QGIS.
1. In your QGIS document, select Plugins>Delimited text>Add delimited text layer
2. In the dialog box, click Browse and find your newly created file
3. Create a layer name
4. Since your text file is tab-delimited, make "\t" your delimiter for this import
5. Click the Parse button to validate your input (Parse will also attempt to find your columns that hold the latitude and longitude)
6. Ensure the X and Y fields have selected the appropriate columns in your text.
7. Press OK!
purtroppo il plugin non fa il suo mestiere e ho ricavato un file kml dal sito di geocoding che qgis mi fa vedere
volendo mettere uno shapefile con lo stradario della città di torino scaricata dal sito del comune dove sono concentrati gran parte dei punti non riesco a vedere nulla di questi dati
se metto uno shapefile della regione piemonte vedo che tutti i punti sono nella città di torino (quindi ho dedotto che sono georeferenziati allo stesso modo)
ho provato anche con i plugin per avere googlemaps o osm di base sotto ma evidentemente c'e' un problema con la versione di qgis a scaricare alcuni plugin
qual è il problema che si genera secondo voi ? debbo fare delle conversioni di scala ? eliminare i punti fuori torino che sono sicuramente degli errori ?
grazie
nico
