Qualcuno sa se esiste una versione di shalstab [0] per GRASS ?
non riesco a far funzionare quello su jgrass
[0] http://calm.geo.berkeley.edu/geomorph/shalstab/index.htm
Ciao Luca,
2013/1/20 Luca Lanteri <mescal72@gmail.com>
non l’ho mai provato, ma puo` essere r.debrisflow?
ciao madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Googlando, pare che il codice non sia disponibile online, ma bisogna scrivere all’autore, hmmm
vedi qui http://www.mergili.at/gisresources_main.html
in :
Sandmeier, Damm, and Terhorst, 2010, GIS-based modeling of debris flow processes in an Alpine catchment, Antholz valley, Italy, Geophysical Research Abstracts Vol. 12, EGU2010-6566-2, EGU General Assembly
dicono:
“Furthermore it is a freely available and opensource software and can thus be improved and extended.”
ciao madi
On Sun, Jan 20, 2013 at 9:08 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Ciao Luca,
ciao madi
Margherita DI LEO
Postdoctoral ResearcherEuropean Commission - DG JRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.euDisclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Margherita DI LEO
Via Fermi, 2749
Ciao Luca,
non l'ho mai provato, ma puo` essere r.debrisflow?
ecco il link:
(Sarebbe da aggiungere sul GRASS Wiki / Addons...)
ciao
Ciao Markus,
2013/1/20 Markus Neteler <neteler@osgeo.org>
Ciao Luca,
ecco il link:
http://www.mergili.at/gisresources_main.html(Sarebbe da aggiungere sul GRASS Wiki / Addons…)
Anche se il codice non e` online? (almeno io non lo trovo…)
ciao madi
Margherita DI LEO
Via Fermi, 2749
On Sun, Jan 20, 2013 at 9:36 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Ciao Markus,
wrote:
> Ciao Luca,
> non l'ho mai provato, ma puo` essere r.debrisflow?ecco il link:
http://www.mergili.at/gisresources_main.html(Sarebbe da aggiungere sul GRASS Wiki / Addons...)
Anche se il codice non e` online? (almeno io non lo trovo..)
Ah, no... l'autore sarebbe da invitare di pubblicarlo (altrimenti
la pagina è poco utile). Con le mie risorse limitate in questo
periodo non posso scrivere a lui... ancora pochi email al
giorno
ciao
Ah, no… l’autore sarebbe da invitare di pubblicarlo
ooook, ricevuto
Margherita DI LEO
Via Fermi, 2749
Ciao Madi,
non credo centri molto debrisflow, shalstab e' un modello di stabilita
di pendio.
Luca, giusto che proprio oggi ho fatto girare Shalstab senza problemi,
mi piacerebbe sapere cosa non riesci a fare andare.
considerato che da anni viene insegnato ai corsi di ingegneria di
Trento, dovrebbe essere bello stabile.
Quando dici JGrass, intendi uDig + jgrasstools?
Ciao,
Ciao Luca,
ciao madi
Margherita DI LEO
Via Fermi, 2749
European Commission._______________________________________________
Gfoss@lists.gfoss.it
I messaggi di questa lista non hanno relazione diretta con le posizioni
dell'Associazione GFOSS.it.
630 iscritti al 1.12.2012
Ciao Andrea,
Il problema è che non sono riuscito ad installare jgrass su ubuntu 12.10 32bitUtilizzando l’installazione mediante plugin (da udig Versione 1.2.3) se provo ad installarlo come plugin ottengo questo errore all’apertura di una qualsiasi mappa :
Could not open the editor: An unexpected exception was thrown.
il log è questo:
!ENTRY org.eclipse.ui 4 0 2013-01-21 09:19:04.777
!MESSAGE Unable to create editor ID net.refractions.udig.project.ui.mapEditor: An unexpected exception was thrown.
!STACK 0
Ho provato in alternativa a scaricare jgrass da qui (quikndi con udig (Versione: 1.2-M9): http://code.google.com/p/jgrass/downloads/list
Dopo aver configurato mapset e gisbase path ho diversi problemi a caricare i layer presenti nel mapset. Quando cerco di selezionare il layer su cui lavorare mi viene proposto uno solo dei layer presenti nel mapset e comunque non riesco a selezionarlo (la finesatra di selezione non si chiude dando ok).
Quando invece provo a caricare la grafica della regione attiva ottengo questo errore:
An internal error has occurred.
null argument:
Purtroppo avevo poco tempo per cercare di capire il problema quindi ho rinunciato. Se vuoi ti mando qualche dettaglio in più.
Grazie mille
Luca
Il giorno 20 gennaio 2013 22:08, andrea antonello <andrea.antonello@gmail.com> ha scritto:
Ciao Madi,
non credo centri molto debrisflow, shalstab e’ un modello di stabilita
di pendio.Luca, giusto che proprio oggi ho fatto girare Shalstab senza problemi,
Quando dici JGrass, intendi uDig + jgrasstools?Ciao,
AndreaOn Sun, Jan 20, 2013 at 9:08 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Ciao Luca,
ciao madi
Margherita DI LEO
Via Fermi, 2749
dell’Associazione GFOSS.it.
Ciao
io conosco bene martin...
posso sentirlo..
gli scrivo
ciao
Il giorno dom, 20/01/2013 alle 21.47 +0100, Margherita Di Leo ha
scritto:
Ah, no... l'autore sarebbe da invitare di pubblicarloooook, ricevuto
Margherita DI LEO
Via Fermi, 2749
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: ivan.marchesini@irpi.cnr.it
ivan.marchesini@gmail.com
fax (mailfax): +39 1782092534
jabber: geoivan73@jabber.org
skype: geoivan73
Grazie Ivan, gli ho scritto, se non mi risponde ti faccio sapere
2013/1/21 ivan marchesini <ivan.marchesini@gmail.com>
Ciao
io conosco bene martin…
posso sentirlo…
gli scrivo
ciaoIl giorno dom, 20/01/2013 alle 21.47 +0100, Margherita Di Leo ha
scritto:2013/1/20 Markus Neteler <neteler@osgeo.org>
ooook, ricevuto
Margherita DI LEO
Via Fermi, 2749
630 iscritti al 1.12.2012–
http://en.wikipedia.org/wiki/Open_formatIvan Marchesini
Perugia (Italy)
Socio fondatore GFOSS “Geospatial Free and Open Source Software” http://www.gfoss.it
skype: geoivan73
Margherita DI LEO
Via Fermi, 2749
Grazie Ivan !
tra l’altro ho visto che ha sviluppato anche altri interessanti modelli: r.avalanche e r.rotstab.
Il giorno 21 gennaio 2013 10:34, ivan marchesini <ivan.marchesini@gmail.com> ha scritto:
Ciao
posso sentirlo…
gli scrivo
ooook, ricevuto
Margherita DI LEO
Via Fermi, 2749
Perugia (Italy)
skype: geoivan73
ci sono novità? è stato pubblicato?
la pagina indicata non esiste
s.
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/shalstab-tp7580774p7587623.html
Ciao,
se ti può interessare abbiamo provato a sviluppare un modulo per grass 7. Lo
trovi negli addons sotto il nome 'r.shalstab'.
Rimaniamo disponibili per qualsiasi suggerimento
d
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/shalstab-tp7580774p7587624.html
se ti riferisci a r.rotsatb posso dirti che non è stato pubblicato
perchè è sottoposto a pesanti revisioni..
tra l'altro per risolvere alcuni problemi è stato coinvolto anche markus
metz.
la nuova versione si chiamarà r.slope.stability..
la stiamo provando.
per ora c'è un paper pubblicato che riguarda il vecchio codice:
http://www.sciencedirect.com/science/article/pii/S0169555X13004972
ho la certezza (ne ho parlato con Martin) che dopo aver pubblicato un
articolo o due (ci stiamo lavorando) sul nuovo codice, lo rilasceremo.
riguardo a shalstab:
http://grass.osgeo.org/grass70/manuals/addons/r.shalstab.html
ciao
Ivan
la pagina indicata non esistes.
666 iscritti al 22.7.2013
ah bene, sono contento di avere rispolverato questo thread.
grazie mille delle informazioni. ora leggo e vedo un po'
grazie ancora
s.
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/shalstab-tp7580774p7587630.html
