Ciao lista, in particolare Sandro,
sto provando a compilare spatialite 2.4.0 RC4 in Ubuntu 10.10.
Mi sembra di aver compilato senza problemi libspatialite_amalgamation-2.4.0 e spatialite-tools-2.4.0.
Quando ho provato a lanciare ./configure in /spatialite_gui-1.4.0 ho avuto questo errore
configure: error: 'libgaiagtaphics' is required but it doesn't seems to be installed on this system.
e qui ti segnalo solamente che credo ci sia un refuso nell'errore: "libgaiagtaphics" invece di "libgaiagraphics".
Poco male, ho provato a compilare /libgaiagraphics-0.4, avendo però come risultato:
ale@dobby:~/sources/libgaiagraphics-0.4$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for string.h... (cached) yes
checking for memory.h... (cached) yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for inttypes.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdint.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking jerror.h usability... yes
checking jerror.h presence... yes
checking for jerror.h... yes
checking geotiff.h usability... no
checking geotiff.h presence... no
checking for geotiff.h... no
configure: error: cannot find geotiff.h, bailing out
e qui mi sono bloccato, avendo controllato di avere le varie librerie geotiff possibili installate...
Che si fa?
Sto facendo i passi giusti o ho sbagliato strada?
grazie
Ale
