FYI. Chi lo usa (e fa bene), please dia feedback.
Saluti.
-------- Messaggio originale --------
Oggetto: [TinyOWS-users] [ANN] TinyOWS 1.0.0 release
Data: Wed, 8 Feb 2012 14:52:00 -0800
Mittente: Olivier Courtin <olivier.courtin@gmail.com>
Rispondi-a: TinyOWS users discuss list <tinyows-users@lists.maptools.org>
A: TinyOWS users discuss list <tinyows-users@lists.maptools.org>,
tinyows-dev@lists.maptools.org, mapserver-users@lists.osgeo.org
Hi alls,
TinyOWS 1.0.0 official release is (finally) out !
You could download it from:
<http://tinyows.org/tracdocs/release/tinyows-1.0.0.tar.bz2>
(checksum 25c9567848b97a3ad9a111c0053e4248)
ChangeLog:
- Configuration change with broken backward compatibility:
* default config file is now /etc/tinyows.xml
* default schema dir is now $PREFIX/share/tinyows/schema
* rename server and prefix to ns_uri ans ns_prefix
* rename wfs_display_bbox to display_bbox
- Encoding support, written by Carlos Ruiz: cruizch@gmail.com <mailto:cruizch@gmail.com>
- Estimated_bbox option for GetCapabilities response (default is false)
- Schema cache for fast-cgi mode (huge performance improvement on transaction
operations)
- Improve drasticaly GetCapabilities performance on huge layer (Thanks to Nicklas
Aven for report)
- Add ability to use different names for layer and storage table (table property)
- Mapfile config file support (use related TINYOWS_MAPFILE env. var)
- Debug option available from configure step (--enable-debug)
- Improve result from --check option
- Add wfs_default_version config file option, to set server default WFS Version
- Add gml_ns config file option, to set if any, layers properties using GML namespace
- Add log_level config file option, to allow more granularity in log output
- PostGIS version init check (support 1.5 and coming 2.0)
- Update XSD schema (WFS, FE, GML), so need a new 'make install' step if you upgrade
- CITE WFS-T 1.0.0 SF-0 full compliant (require PostGIS 2.0)
- CITE WFS-T 1.1.0 SF-0 full compliant (require PostGIS 2.0)
- Lot of debug stuff (a special thanks to Boris Leukert, Jukka Rahkonen and Even
Rouault for detailled reports)
- Security fixes (SQL Injection vulnerability - Reported by Even Rouault)
Thanks again to all folks who contributed on it !
Olivier
