GN 4 harvester not able to harvest a pyCSW endpoint
Hallo community,
We have encountered a scenario where the harvester in our GeoNetwork 4.2.2 is not able to harvest records form a pyCSW endpoint. However, the harvester in a GeoNetwork 3 instance is able to successfully harvest this endpoint.
In troubleshooting we are trying to understand, was there a significant change in the harvesters between GN3 and GN4 that this is happening? Has anyone else encountered this and were you able to solve it?
Thanks!!
Hi
Are there any errors in the harvester’s log? If so, please send us the log file.
Also, if you could tell us which CSW server you are trying to harvest, that would be a great help in resolving the issue.
Jose García
