Google Summer of Code 2026
Interessante proposta di sviluppo per QGIS, finanziabile entro la Google Summer of Code 2026:
QGIS already has an extensive set of processing algorithms. However once an algorithm is executed the only way to modify its result is to re-run the algorithm altogether. The idea of this GSoC is to introduce a much more flexible way to run algorithm and edit the result through a new non-destructive layer called a “processing layer” and its associated data provider.
