I installed the Grass4.1 binaries for Solaris 2.3 on our SPARCserver 690.
One of my users says that it does not work correctly.
After creating and defining my LOCATION region, GRASS asks :
"{ Do you accept this region? (y/n) }" for which my answer is y
GRASS hangs here!!!! The next question should have asked for
projection.
If I hit the return key, I get the following message:
"{ LOCATION <matthew1> created
But the Projection information files were not created!
You must run g.setproj successfully before projection software will
work. }"
I would be grateful if you could help me out.
Thanks
Venu
(venu@utk.edu)
