I have a serious problem with my GRASS database following a Ubuntu system crash where I was running a GRASS script processing a lot of data; the script runs so fast that my cpu overheats and the system locks up (obviously NOT a GRASS issue – on my desktop machine, if I put in a 5 sec sleep, the cpu does not overheat; curiously, on my laptop Ubuntu machine the sleep is not needed!!! Go figure…)
Anyhow, I have the error that appears in the GRASS 8.4 console attached in a text file. This appears for all my GRASS PROJECTS (LOCATIONS). How can I fix this error, fix what’s corrupted?
Thank you,
Tom
(attachments)
grass_console_error.txt (1.82 KB)
