Keith,
you need to use the mknod command while logged in as root to create
a named pipe. The general form of the command is:
/usr/etc/mknod filename p
To create the fifo pair 1.a/1.b which would be needed to support
a single grass monitor:
mknod fifo.1a p
mknod fifo.1b p
chmod 666 fifo.1a
chmod 666 fifo.1b
In referance to the pipes in the dev diectory.
I brought the 4.1 binaries off the moon and successfully
unpacked it. It starts fine but will not start a monitor.It apparently does not find the fifo's in the grass/dev directory
and in fact: the directory is empty.I seem to recall trying to copy fifo's to no avail before
and since I am new to unix I ran for the Unix Bible and
found only terse entries on fifo's. It said they are named
pipes without saying how to move, render or create them.So, what is the answer to this unix cipher?
Where o where can I get my fifo's from?
Keith M. Mitchell
University of Illinois
Department Of Agronomy
S 310 Turner Hall
Urbana, Illinois 61801217 - 333 - 4424
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
