[GRASS-dev] 6.4.4 planning
I started compiling GRASS 6.4, release branch last Friday but was only able to test it today. It seems to work fine under Mavericks for Mac.
Here are a couple a minor issues I noticed.
When I first tried to use nviz (3D display), it failed, with an error message in the console. But it worked fine every time since then, even after restarting GRASS.
Also, there is chatter in the terminal on opening nviz.
GRASS_INFO_MESSAGE(75334,4): Loading raster map elevation@PERMANENT…
GRASS_INFO_END(75334,4)
GRASS_INFO_PERCENT: 0
GRASS_INFO_PERCENT: 3
GRASS_INFO_PERCENT: 6
GRASS_INFO_PERCENT: 9
and
GRASS_INFO_MESSAGE(75334,6): Translating colors from raster map elevation@PERMANENT…
GRASS_INFO_END(75334,6)
Probably a simple fix if you know where to find it.
MIchael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Dec 12, 2013, at 11:32 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
At the moment, GRASS 6.5 is not compiling on the Mac under OS X 10.9 (Mavericks).
Michaesl
C. Michael Barton
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 12, 2013, at 11:23 PM, grass-dev-request@lists.osgeo.org wrote:
Subject: Re: [GRASS-dev] 6.4.4 planning
Date: December 12, 2013 at 3:01:22 PM MST
To: GRASS developers list <grass-dev@lists.osgeo.org>
On Sun, Nov 24, 2013 at 4:32 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Markus Neteler wrote
On Sat, Nov 16, 2013 at 3:00 AM, Hamish
on the grass-user ML Markus N wrote:
(and it is time to get 6.4.4 out…)
“Important bugs concerning the next release”
https://trac.osgeo.org/grass/report/13
see http://trac.osgeo.org/grass/ticket/2138 for the actual state of python
addons in winGRASS6.5.svn/6.4.svn.
we are near to working python addon scripts in winGRASS :slight_smile:
this seem to be the one and only thing blocking 6.4.4RC1…
Any suggestions to get it done?
On Tue, Dec 17, 2013 at 11:02 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
GRASS_INFO_MESSAGE(75334,4): Loading raster map <elevation@PERMANENT>...
There is a similar ticket open:
https://trac.osgeo.org/grass/ticket/312
How to catch this GRASS_INFO_PERCENT output?
Hi devs,
some time passed, so we should push RC1 out of the door:
Please check:
"Important bugs concerning the next release"
and please help to complete the draft release notes:
https://trac.osgeo.org/grass/wiki/Release/6.4.4RC1-News
thanks
Hi devs,
in order to prepare the 6.4.4RC1, please check:
I have updated to some extent the draft release notes (please add more):
On Sun, Apr 20, 2014 at 7:38 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
now v.buffer has been fixed by Markus Metz (using the GEOS library).
Please test.
2014-04-29 18:29 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Please test.
cool, I would say that it's time for RC1... Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
Here the full list of issues but none is a blocker:
https://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&group=status&milestone=6.4.4
Ready to tag RC1, I would say.
Hi Markus,
2014-05-05 20:52 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
one big +1. Martin
Draft announcement to be updated:
http://trac.osgeo.org/grass/wiki/Release/6.4.4RC1-News
Here some relevant ones:
To test on Windows:
r.kappa: call to r.stats fails if spaces in path
https://trac.osgeo.org/grass/ticket/2116
g.remove cannot remove vector map because of space in DB layer name
https://trac.osgeo.org/grass/ticket/1438
v.external gui exceeds the border of the screen
https://trac.osgeo.org/grass/ticket/2159
r.univar NaN
https://trac.osgeo.org/grass/ticket/2269
r.walk backport
https://trac.osgeo.org/grass/ticket/1628
v.kcv backport
https://trac.osgeo.org/grass/ticket/2035
Perhaps some could be done before tagging RC1?
Thanks for having solved some of the issues in the past 24 hours.
To test on Windows:
... to be tested.
r.univar NaN
... missing output to be changed (all GRASS versions).
r.walk backport
... not sure what to backport.
v.kcv backport
... any objections to submit the patch?
And/or I can tag RC1 now and we do these issues later.
To test on Windows:
You note that this should be wontfix. What do you want to be tested ?
r.univar NaN
I see this more as an enhancement request than a bug. I don't think this should hold up a release.
r.walk backport
v.kcv backport
See my comment in the ticket.
I think that except for the r.walk segfault, none are really showstoppers. And even that only seems to be reproducible in a very specific situation.
Moritz
On Fri, May 16, 2014 at 2:38 PM, Moritz Lennert
To test on Windows:
Right, nothing to be tested I guess. To be closed?
r.univar NaN
ok.
r.walk backport
Markus Metz may have an idea.
v.kcv backport
The vector overwrite issue in other mapsets seems to be a general
problem, see ticket.
Given the recent discussion elsewhere I am stuck here.
Do you want me to tag RC1 or wait ...?
To test on Windows:
Yes.
r.walk backport
v.kcv backport
Yes, and I think this is serious enough to solve this before release, even if people seem to have lived with it for a long time...
I think that we should try to structure the entire release process a bit more as we are currently dealing with two release processes in parallel (6 and 7) and I have the feeling that this is a bit overwhelming for our little team and that the lack of clear structure of the process leads to the frustrations seen on the list lately.
I would, therefore, propose to focus on 6.4.4 for now, getting that out of the door before we work on 7.0 (especially since there seem to be some fundamental issues to be solved before releasing anything).
I also think that we should work out a clear calendar for that release with official announcements of freeze policy.
I think we are not far at all from releasing, so maybe something like this:
- Real freeze of grass64_release at the end of this week. This means that any backports from grass6_devel should happen before that moment. But only non-invasive and well-tested elements should be backported.
- RC1 beginning of next week
- Bug squashing effort during the two weeks that follow.
- RC2 around June 15th.
- Another week of bug squashing, if necessary.
- Release of 6.4.4 by end of June, the latest.
That sound ok ?
Moritz
2014-05-26 12:58 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
  • Real freeze of grass64_release at the end of this week. This means that any backports from grass6_devel should happen before that moment. But only non-invasive and well-tested elements should be backported.
  • RC1 beginning of next week
  • Bug squashing effort during the two weeks that follow.
  • RC2 around June 15th.
  • Another week of bug squashing, if necessary.
  • Release of 6.4.4 by end of June, the latest.
That sound ok ?
sounds good to me… Martin
On Mon, May 26, 2014 at 12:58 PM, Moritz Lennert
Seems nothing got backported in the past week any more:
http://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4
Should that happen then?
At the same time, we did not officially announce the calendar (it was in a reply to a long-going thread...). But let's hope all the interested people saw the calendar.
I think (also in line with the above) a clear freeze announcement has to go out first to give a 24-48h warning to everyone. Then RC1 can be tagged.
Sorry, but I won't be of much help these days as we've started exams here and I'll be busy with that almost all week.
Moritz
On Mon, Jun 2, 2014 at 10:41 AM, Moritz Lennert
only
saw the calendar.
Yes.
So I'll wait...
cheers
hi all,
I would be able to tag RC1 tomorrow (Friday) if there are no objections.
Are there any pending backports? I have some uncommitted fixes for
r.pack and v.external but will not commit them to avoid another
flamewar. :slight_smile:
Hi Markus,
2014-06-05 9:56 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
no objection for my side. From other project (GDAL for example) I got
feeling that RC period must be short. So e.g. RC2 or final one/two
weeks after RC1.... Also reporting bunch of blockers during RC stage
can be interpreted as attempt to block release. I hope that for GRASS
7 will defined fixed time-based release policy with freeze stage
(one/two months - ideal time for reporting blockers), than simply
release and go on...
Martin
2014-06-05 17:47 GMT+02:00 Moritz Lennert <moritz.lennert@ulb.ac.be>:
As I've already told Markus off-list, I think that in order for this to work
we would need a clearly defined release-process with clear announcements of
the different steps (pre-freeze warning sufficiently early, freeze
announcement, pre-tag announcement, etc) and a strict respect of the rules
during this process (i.e. no non bugfix commits during a freeze), etc.
I'm not convinced that a time-based release-policy is the solution, but I
think a more clearly defined release-process policy might help in avoiding
frustrations.
right, let's push out 6.4.4 somehow, new release policy is question for G7...
Martin
