[GRASS-dev] About gsoc project
I am adithya from India and this is my statement of proposal for the osgeo grass gis project. How and what should i contribute to the project or osgeo before submitting my proposal. Give feedback and suggestions if there is any mistake in the proposal. Apart from mailing lists, are there any other platforms to interact with the community.
(attachments)
Untitled document.pdf (57.5 KB)
Resume-Adithya-A.pdf (127 KB)
Hi Adithya,
Welcome to the grass-dev mailing list. I’ll answer inline:
On Wed, 6 Apr 2022 at 11:03, adinayyu <adinayyu@gmail.com> wrote:
…my statement of proposal for the osgeo grass gis project.
Good topic. The pytest is important!
The “test of skills” specified on the wiki still applies. You will need to be familiar with both the new (pytest) and the old (grass.gunittest) system. So, start with fixing a couple failing tests. There is a list of failing tests in the .gunittest.cfg file in the root directory of the repo.
https://github.com/OSGeo/grass/blob/main/.gunittest.cfg
You should also write some new tests. This can now be done with both grass.gunittest and pytest. You will get familiar with the grass.gunittest tests while fixing the existing tests. There are a couple of experimental tests which use pytest. Here are some simple examples:
https://github.com/OSGeo/grass/blob/main/python/grass/script/tests/utils_test.py
https://github.com/OSGeo/grass/blob/main/python/grass/script/tests/grass_script_setup_test.py
How much do you need to write? More is better because you will get familiar with more aspects of the testing, but start small. One PR with one fixed test file from .gunittest.cfg.
Good for starters. You will need to extend it beyond what is on the wiki to increase chances of your application. Doing the above tasks will help you in that.
When you submit a PR, people will react with comments and reviews. That’s the most direct way of getting feedback for your code. For general questions about development, the grass-dev mailing list is the best. We have also grass-user focused on running the software itself and GitHub Discussions.
First of all, you should familiarize yourself with GRASS GIS and create a development environment for GRASS GIS on your computer - that is compile the code and make sure you can modify it and compile again - if you are using Windows, the best way is to set up a Ubuntu virtual machine and do the development there.
You can skip ahead a little bit and use GRASS GIS online through JupyterLab on Binder. Not a good way for doing development, but a great way of getting familiar with the software through Python (most relevant for your GSoC topic) and even the build environment because there is actually all the code and you have access to the command line from there.
8.0.1 release: https://mybinder.org/v2/gh/OSGeo/grass/8.0.1?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fbasic_example.ipynb
development version: https://mybinder.org/v2/gh/OSGeo/grass/main?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fgrass_jupyter.ipynb
Best,
Vaclav
