[GRASS-dev] adding files to the release branch?
I'm trying to add the v.dissolve and v.centroids scripts to the 6.2
release branch but can't figure out how to add files to the branch.
I get:
6.2branch/grass6/scripts$ cvs add v.centroids/Makefile
cvs add: cannot open CVS/Entries for reading: No such file or directory
cvs [add aborted]: no repository
6.2branch$ cvs add grass6/scripts/v.centroids/Makefile
cvs add: in directory `.':
cvs [add aborted]: there is no version here; do `cvs checkout' first
(doing this without a full checkout of the whole 6.2 branch [but
scripts/ is checked out], dirs+files exist in HEAD)
thanks,
Hamish
I get:
  cvs update -j HEAD v.centroids
  cvs commit v.centroids
> I get:
> directory cvs [add aborted]: no repository
I'm not sure if I'm using -j correctly; however, I got it done.
what worked:
cd 6.2branch/grass6/scripts/
cvs tag -r HEAD releasebranch_6_2 v.centroids/
thanks,
Hamish
> > I get:
what worked:
The "cvs tag" command should be unnecessary.
The main difference between "cvs update -j" and "cvs update -r" is
that -r tags the updated version with the tag used to retrieve it,
while -j will use the current tag (i.e existing files will retain
their tag, new files will get the tag from the CVS/Tag file).
