here a win 10 with german locale; setting preferences in GRASS to en, then I
get:
All attempts to enable English language have failed. GRASS running with C
locale.
If you observe UnicodeError in Python, install en_US.UTF-8 locale and
restart GRASS.
get:
locale.
restart GRASS.
then I
get:
locale.
restart GRASS.
"My question was how widespread C.UTF-8 is as a locale present on machines.
all the things mentioned in the ticket and the message may work in *nix
environments, not sure that this will work in win (e.g. [1], [2], ...) and
mac.
2017-11-25 11:46 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
get:
locale.
restart GRASS.
what does this mean?
It means that you want to run GRASS in a language that is not
supported on your system. Attempts to switch GRASS + any related
programs that GRASS might be calling to English have failed. Your
GRASS session will run with C locale. It is not the same as en_US and
thus, although you might see messages in English (due to fact that
they are in English in the source code), it will not behave as it
should for a proper (US) English language (i.e. sorting will be "A B C
a b c" versus your expected "a A b B c C"). One more bad thing will be
defaulting to ASCII encoding thus most likely causing a failure at the
first encounter with "Österreich" (still "schadenfreude" will be
fine). To enjoy a proper English experience in GRASS, you should
install en_US.UTF-8 locale on your system. If you think – how QGIS
manages to deal with it –, here GRASS modularity bites us, besides
everything in QGIS-land is also not so fine with language switching.
Unfortunately I do not have access to recent Windows boxes (I have a
Vista VM), neither MacOS thus patches solving problems on those OSes
will have to be provided by GRASS Windows and Mac developers.
then I
get:
locale.
restart GRASS.
r.category map=myrast@user1
1 österreich
2 schadenfreude
3 lokalität
at least this one works
in theory, this language package could be installed in win 10:
English LanguagePack - Windows 10 Version 1709 for x64-based Systems
(KB4046355) [en-US_LP]
