[GRASS-dev] any special reason why choice of raster compression method is done via environmental variable ?
Hi Markus,
In recent days, I've been confronted several times with the issue of people trying to share data among themselves, but using different versions of GRASS, and so raster data compressed in a more recent version of GRASS was not usable in an older version of GRASS.
Now, I agree that generally the solution is to tell people to use the latest and greatest, but this is not always possible / it is not necessarily highest on the list of priorities of people to see how they can install the latest version of GRASS within their particular environment.
Obviously, those with the latest version of GRASS can simple recompress using ZLIB. However, compression method is defined as an environment variable. This is somewhat daunting to many MS Windows users out there. Is there any specific reason that lead to the choice of not using a parameter to allow the choice of compression method (possibly to override a default that is still defined by an environment variable) ?
Moritz
What should be the solution? Moving to choice set by g.gisenv?
Māris.
trešd., 2019. g. 4. dec., plkst. 11:28 — lietotājs Moritz Lennert
(<mlennert@club.worldonline.be>) rakstīja:
Hi Markus,
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Le Thu, 5 Dec 2019 08:30:43 +0200,
As mentioned in my mail, I suggest to add a parameter to the module
which allows to override the default setting when compressing a
specific raster map.
Using a GRASS environment variable instead of a shell variable might be
an idea to make setting the default easier.
Moritz
> Hi Markus,
> Moritz
Département Géosciences, Environnement et Société Université Libre de
Bruxelles Bureau: S.DB.6.138
CP 130/03
Av. F.D. Roosevelt 50
1050 Bruxelles
Belgique
tél. + 32 2 650.68.12 / 68.11 (secr.)
fax + 32 2 650.68.30
Hi Moritz,
On Wed, Dec 4, 2019 at 10:28 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Markus,
In recent days, I’ve been confronted several times with the issue of
Such a parameter would need to be added to every module creating raster output.
The reason for an environment variable is historical: previously, CELL maps were by default compressed with RLE, this could be changed with the env var GRASS_INT_ZLIB. This mechanism of using an env var for raster compression has been extended.
Other solutions than an env var would be to use g.gisenv/$GISRC to set the default compression method per user or a mapset-specific compression method (to be set with a modified r.compress?) stored in the mapset’s VAR file.
Regarding MS Windows users + raster compression: I think it is reasonable to assume at least GRASS 7.6 which has support all compression methods available in GRASS.
Markus M
On 9/12/19 22:50, Markus Metz wrote:
Hi Moritz,
On Wed, Dec 4, 2019 at 10:28 AM Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
> Hi Markus,
My request is more linked to use cases where one would like to share data (e.g. with r.pack) with other GRASS GIS users who do not necessarily have access to the same compression method, not necessarily to changing the default compression method. I was just wondering whether it might be easily possible to just implement r.compress method= as a quick way to recompress a specific map with a chosen method, overriding the default method. Currently, to do that, you have to change the default method by changing the env variable, run r.compress, then change the variable back to the value one wishes generally to use as default.
Obviously, you can always just export as tiff and share that, but that just feels less elegant. Anyway, this is probably somewhat of a luxury problem :slight_smile:
Moritz
Hello all,
I try to import with GRASS78 in parallel Sentinel-2 data with "i.sentinel.import -r" (Multicore VM (32 cores -> 31 parallel processes)).
Sometimes the following error occurs (note the formatting comes from deploying in actinia):
          "99..Reprojecting <T32ULB_20181010T104019_B08_10m>...",
          "96..100",
          "90..99..96..100",
          "99..93..100",
          "99..100",
          "96..96..99..100",
          "99..100",
          "Estimated target resolution for input band <T32ULC_20180702T104019_B04_10m>: 9.998178838141047",
          "Estimated target resolution for input band <T32ULC_20181010T104019_B04_10m>: 9.998178838141047",
          "Estimated target resolution for input band <T32ULB_20180930T104019_B08_10m>: 9.998178838136036",
          "Estimated target resolution for input band <T32ULC_20180806T104021_B04_10m>: 9.998178838141047",
          "Estimated target resolution for input band <T31UGT_20180806T104021_B08_10m>: 9.26372380446332",
          "Estimated target resolution for input band <T31UGT_20181010T104019_B08_10m>: 9.26372380446332",
          "ERROR: Region file mapset_a6335f7028114ee9989530cb55874785//WIND is empty", <---- here
          "Using given resolution for input band <T32ULC_20180702T104019_B04_10m>: 10.0",
          "Using given resolution for input band <T32ULC_20181010T104019_B04_10m>: 10.0",
          "Using given resolution for input band <T32ULC_20180806T104021_B04_10m>: 10.0",
          "Reprojecting <T32ULC_20181010T104019_B04_10m>...",
          "Reprojecting <T32ULC_20180702T104019_B04_10m>...",
          "Traceback (most recent call last):",
          " File \"/usr/local/grass7/scripts/r.import\", line 403, in <module>",
          " sys.exit(main())",
          " File \"/usr/local/grass7/scripts/r.import\", line 355, in main",
          " grass.use_temp_region()",
          " File \"/usr/local/grass7/etc/python/grass/script/core.py\", line 1216, in use_temp_region",
          " run_command(\"g.region\", save=name, overwrite=True)",
          " File \"/usr/local/grass7/etc/python/grass/script/core.py\", line 441, in run_command",
          " return handle_errors(returncode, returncode, args, kwargs)",
          " File \"/usr/local/grass7/etc/python/grass/script/core.py\", line 343, in handle_errors",
          " returncode=returncode)",
          "grass.exceptions.CalledModuleError: Module run None g.region --o save=tmp.r.import.19907 ended with error",
          "Process ended with non-zero return code 1. See errors in the (error) output.",
          "grass.exceptions.CalledModuleError: Module run None g.region --o save=tmp.r.import.20767 ended with error",
          "Processing <T32ULB_20180930T104019_B04_10m>...",
          "Using given resolution for input band <T31UGT_20181010T104019_B08_10m>: 10.0",
          "Processing <T31UGT_20180806T104021_B04_10m>...",
          "Reprojecting <T32ULC_20180806T104021_B04_10m>...",
          "Reprojecting <T31UGT_20181010T104019_B08_10m>...",
          "WARNING: Projection of dataset does not appear to match current location.",
I found out that r.import uses temp_region and that this sets an environment variable WIND_OVERRIDE:
    https://github.com/OSGeo/grass/blob/4dc36bb86fa9181259fa7f9b9472f8d3bc4e787e/lib/python/script/core.py#L1281
    os.environ['WIND_OVERRIDE'] = name
And in parallel processing the variable is set by each process and the temp_region can be deleted to early.
Does anyone know if this is the reason of my error and how to fix this?
Best,
Anika
One workaround may be GRASS_COMPRESSOR=method r.compress, but it won’t directly work on MS-Windows without a batch file, I think.
Huidae
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
On Tue, Dec 10, 2019 at 6:47 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Moritz,
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
Hi Markus,
environment.
output.
recompressing an existing raster map seems like a waste of time. Why not compress it in the first place with the appropriate method?
Recompressing an existing map with a chosen method via r.compress method=XY means that a new raster map should not be compressed with the default method but another supported method. This would require a new function in lib/raster like Rast_open_new_compression_method() that overrides the default compression method. Of course this is possible, but it requires substantial changes to lib/raster.
About the use cases:
People want to share a mapset: in this case all GRASS raster maps should be compressed with the most compatible compression method (ZLIB). Currently, this can be done with an env var. Alternatively, a new mechanism via g.gisenv could be established.
Another option could be to set the default compression method per mapset, to be stored in in the mapset’s VAR file, to be set with e.g. r.compress method=.
The point is that it is fairly easy to set a suitable compression method before the raster lib is initialized, and there are different possible mechanisms apart from the current method using an env var that are easy to implement.
This only a luxury problem if you don’t need to care about processing speed and disk usage. The different compression methods by now available in GRASS allow for optimization for speed (LZ4) or for optimization for disk usage (BZIP2 for larger CELL maps). An easy (easier) way to set the compression method seems reasonable.
Markus M
Moritz
Coming back to this to continue the discussion:
On 15/12/19 21:41, Markus Metz wrote:
On Tue, Dec 10, 2019 at 6:47 AM Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
> > Hi Moritz,
> > <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be> <mailto:mlennert@club.worldonline.be>> wrote:
> > > Hi Markus,
> > environment.
> > output.
Because what you consider the appropriate method at the time creation of the data (and still the appropriate method for your actual work) might not be the appropriate method for sharing with someone using a different system.
Ok, I understand that this is complicated.
This would already make life easier for Windows users who (for the majority) are not used to env variables (and this is becoming more and more true of GNU/Linux users as well...).
Another option could be to set the default compression method per mapset, to be stored in in the mapset's VAR file, to be set with e.g. r.compress method=.
That would probably be a nice solution. One could then create an "Export" mapset which can then be easily shared.
This only a luxury problem if you don't need to care about processing speed and disk usage. The different compression methods by now available in GRASS allow for optimization for speed (LZ4) or for optimization for disk usage (BZIP2 for larger CELL maps). An easy (easier) way to set the compression method seems reasonable.
I didn't mean that compression is a luxury problem, but rather that since the option exists of just exporting the map as a tiff, readable by most systems (and you can chose a sharable tiff compression method at export time), all the above is probably a bit less of a necessity, and I'm just making noise :wink:
Moritz
On Thu, Jan 16, 2020 at 10:56 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Moritz,
mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>> wrote:
Hi Markus,
use the
how they
environment.
recompress
there.
variable) ?
output.
system.
True, for sharing the highest (smallest size) compression method is usually preferred, while for actual work the fastest compression method is usually preferred.
more true of GNU/Linux users as well…).
r.compress method=.
“Export” mapset which can then be easily shared.
You could do the same by creating some “Export” mapset, then setting the compression method and creating raster maps to be exported in this “Export” mapset.
Implementation of a compression method set with g.gisenv is relatively easy.
Implementation of a compression method defined in a mapset’s VAR file is a bit more work and requires a mechanism to set the compression method in a mapset’s VAR file, e.g. r.compress method=.
But, if e.g. the aim is to reduce file size, the best compression method depends on the datatype and size of the individual raster map to be compressed. There is no “one size fits all” method.
I didn’t mean that compression is a luxury problem, but rather that
I’m just making noise :wink:
A sharable tiff compression method is not trivial, it depends on the software and its capabilities used by the receiver.But this is a bit off-topic.
Markus M
Moritz
just for the record (by Markus M):
  https://github.com/OSGeo/grass/pull/287
markusN
