I'm working on a longstanding annoyance in NVIZ: many of the sliders are
presented backwards. (e.g. lighting levels)
this fix isn't complete though: if you type in a new out of range value
& hit <enter> (e.g. Red=1.5) it goes backwards. More importantly, the vector
points size slider gets stuck until you type in a new out of range value. ??
I'm doing a bunch of bug fixes in gism. But I can take a look at this
afterwards.
Do you need to change the resolution setting? This sets the increment
interval.
Command-Line Name: -resolution
Database Name: resolution
Database Class: Resolution
A real value specifying the resolution for the scale. If this value is
greater than zero then the scale's value will always be rounded to an even
multiple of this value, as will tick marks and the endpoints of the scale.
If the value is less than zero then no rounding occurs. Defaults to 1 (i.e.,
the value will be integral).
Michael
Arizona State University
Date: Mon, 4 Sep 2006 21:47:11 +1200
To: grass5 <grass-dev@grass.itc.it>
Subject: [GRASS-dev] backwards sliders in NVIZ
