| Sir,
> My project is based on batch processing in GRASS GIS.
> The following steps have been performed.
> 1)v.in.db
> 2)v.to.rast
> 3)r.surf.idw
> The next step is to do batch processing on the above mapset and the above
> output should be displayed within a particular interval time given by the
> user.
> #!/bin/sh
> TMPDIR=/tmp
> MAINDIR=/Computer/disk/ProgramFiles/QuantumGIS
> MYUSER=$HOME/gbase
> export GISBASE=$MAINDIR/grass
> # the file contains the GRASS variables which define the LOCATION etc.
> echo "GISDBASE: $HOME/gbase
> LOCATION_NAME: Kerala
> MAPSET: PERMANENT
> " > $TMPDIR/.my_grassjob
> export GISRC=$TMPDIR/.my_grassjob
> export PATH=$GISBASE/bin:$GISBASE/scripts:$PATH
> export LD_LIBRARY_PATH=$MAINDIR/lib:$GISBASE/lib:$LD_LIBRARY_PATH
> # settings for graphical output
> PNGOUTPUTDIR=$TMPDIR
> # current date
> DATE=LC_ALL=C date -R | tr -s ' ' ' ' | cut -d' ' -f2,3,4 | tr -s ' ' '_'
> export GRASS_PNGFILE=$PNGOUTPUTDIR/gbase_${DATE}.png
> export GRASS_TRUECOLOR=TRUE
> export GRASS_WIDTH=900
> export GRASS_PNG_COMPRESSION=1
> # use process ID (PID) as lock file number:
> export GIS_LOCK=$$
> ##### the algorithms goes here
> error_routine () {
> echo “ERROR: $1”
> exit 1
> # set region to default settings (here: world)
> g.region -d || error_routine “g.region”
> #open PNG output
> d.mon start=PNG || error_routine “d.mon start=PNG”
> # import the maps:
> v.in.db driver=mysql database=Kerala table=rain x=LON y=LAT output=Location
> key=ID || error_routine “v.in.db”
> v.to.rast input=Location output=Loca use=attr column=ELEV_FT ||
> error_routine “v.to.rast”
> r.surf.idw input=Loca output=surfloca || error_routine “r.surf.idw”
> # display
> d.vect Location || error_routine “d.vect”
> d.rast Loca column=class type=point <br>> themetype=graduated_points maxsize=20 nint=6 || error_routine “d.rast”
> d.rast surfloca || error_routine “d.rast”
> # close PNG output
> d.mon stop=PNG || error_routine “d.mon stop”
> # remove imported map, no longer needed:
> g.remove vect=Location || error_routine “g.remove”
> rm -f $TMPDIR/ $TMPDIR/
> # remove internal tmp stuff:
> $GISBASE/etc/clean_temp || error_routine “clean_temp”
> rm -rf $TMPDIR/grass6-$USER-$GIS_LOCK
> # done.
> echo “Generated $GRASS_PNGFILE”
> Then the above script is performed by these steps:
> chmod u+x $HOME/my_grassjob.sh
> export GRASS_BATCH_JOB=$HOME/my_grassjob.sh
> grass63 ~/grassdata/spearfish60/neteler/
> Problem is concurrent users cannot access it.Display window never opens,
> what is wrong with the above script codings.Please correct it.Also guide me
> how to set the time intervals in batch processing.
> Thank You in advance.
> Regards
