[GRASS-dev] Broken: GRASS-GIS/grass-ci#1922 (master - 0202aa0)
Build #1922 was broken.
5 minutes and 12 seconds
Huidae Cho
0202aa0 Changeset →
Call the DB error handler before the vector handler to avoid busy database warnings
Reproduce this issue in the North Carolina sample dataset:
r.to.vect input=aspect output=aspect type=line
Any unthinned input raster will produce the same issue.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70506 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
