[GRASS-dev] Broken: GRASS-GIS/grass-ci#2206 (master - 1df7517)
Build #2206 was broken.
5 minutes and 13 seconds
Markus Metz
1df7517 Changeset →
sync v.net.alloc and v.net.iso
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71212 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
The new Trusty images are now live! Read all about it on our blog and take note that you can add group: deprecated-2017Q2 to use the previous versions. :penguin: :sparkles:
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
