[GRASS-dev] Broken: GRASS-GIS/grass-ci#397 (master - 9edd649)
Build #397 was broken.
8 minutes and 49 seconds
Martin Landa
9edd649 Changeset →
v.in.ogr not supporting OFTInteger64 field type (#2769)
add support also for Integer64List
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@66564 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis Pro could be your new best friend!
Travis CI is powered by
